Typical max oil pressure for 5th gens??
Old Mar 3, 2004 | 08:23 AM
577HondaPrelude's Avatar
Default Typical max oil pressure for 5th gens??
What's the max oil pressure in a typical OEM h22a4? more than 100psi?
-thanks
Old Mar 3, 2004 | 08:27 AM
jc836's Avatar
Default Re: Typical max oil pressure for 5th gens?? (577HondaPrelude)
Max should be ~80psi cold. At Idle when warm it can dip down to ~20. This assumes that you are using the correct weight oil (52-30).
Old Mar 3, 2004 | 12:57 PM
TimeRacer's Avatar
Cold it's around 75 psi indicated, drops to a little above 65 psi when the car is warm.
Old Mar 3, 2004 | 02:54 PM
flyrod's Avatar
Default Re: Typical max oil pressure for 5th gens?? (TimeRacer)
Out of curiosity I temporarilly put a gauge on a newly rebuilt H22 and it pegged the gauge at idle when cold (~70psi). I think the oil light needs to see 10 psi and the VTP sensor needs to 55 or 60. So I guess those would be absolute minimums you would want (10psi at idle and 55 at 5000 rpm).
Old Mar 4, 2004 | 05:35 AM
Default Re: Typical max oil pressure for 5th gens?? (flyrod)
ok, thanks for the info! I'm putting in a 100psi max sender and wanted to make sure I didn't over range it.
tonydize21
Jun 18, 2011 01:23 AM
Rob97'SH
Feb 9, 2009 10:55 AM
soontobeboost
Jan 6, 2007 06:22 AM
LSVTEC 91 Civic
May 25, 2004 05:56 PM
USDM 4G VTEC
Sep 3, 2003 08:26 PM
