D-SERIES GUYS - B16A TB on D16Y8 Manifold? How?
I bought a 1G B16A TB and i want to mate it to my Y8 manifold...the bolts all match up but other than that all the vaccum channels and such are totally different. There is also no spot for a MAP sensor on the B16 TB.
I know D series guys have used B series TB's on their manifolds i just need to know how. The B16 TB is bare so can i just swap the TPS sensor from a D16 TB?
How about the HICV (high idle control valve on bottom of my D16 TB), it uses coolant flow to allow more air when cold and less air when hot. The B16 TB doesn't have this on it but just 2 coolant lines that pass through the bottom of the TB.
Does this sound right? Will it work correctly? What do i need to do to make it work right?
Thanks in advance i couldn't find much searching but will keep trying,
Vince
Vince
jonesEK
Jun 24, 2011 10:46 PM
Civic Racer X 7
11
Nov 15, 2005 05:22 PM
Wes90civic
Jan 23, 2004 11:37 PM
