HONDATA
Old Mar 3, 2004 | 06:43 AM
BLaCk-S's Avatar
Default HONDATA
ok im goin to go with the hondata ecu flash. just a couple of questions.
1. how do the people that have it like it?
2.could damage be done by high reving all the time and stuff like that?
3.can the dealer find out about it?(warrenty concerns)
4. i just have injen cai. will this do that much or should i go with exhaust first?
Old Mar 3, 2004 | 08:20 AM
BLaCk-S's Avatar
bump
Old Mar 3, 2004 | 08:23 AM
StageOne's Avatar
Default Re: (BLaCk-S)
For most of your questions see the link below. Though you did not tell us what car you have. I took a guess from your username - RSX-S??
http://www.hondata.com/k20a2release.html
Old Mar 3, 2004 | 08:24 AM
BLaCk-S's Avatar
YEA 04 RSX S
Old Mar 3, 2004 | 08:28 AM
BLaCk-S's Avatar
Any increase in RPM limit though is at your own risk. If you suffer engine damage that is related to excessive revs Honda/Acura will not cover your warranty. If this of a concern, upgrade your valve train or use a program with a stock rev limit.
HONDATA SAYS THIS BECAUSE "JUST IN CASE"? OR COULD HTIS LIKELY HAPPEN?
IM REALLY CONCERNED CAUSE I HAD A BAD EXPERIENCED WITH MY PREVIOUS CAR I DONT WANNA SCREW THIS ONE UP.
Old Mar 3, 2004 | 09:18 AM
alohasurftoad's Avatar
Default Re: HONDATA (BLaCk-S)
if you plan to stay with stock internals and normally aspirated, hondata is one of the best mods. it improves horsepower and torque appreciably over the entire powerband. don't expect it to feel like a turbo, though.
although the higher rev limit is provided, if you drive "within reason", you'll be fine.
the dealers are able to find out if you have hondata but unless you give them a reason, they won't look for it.
optimum gains with hondata are realized with a CAI, which you already have. since the catalytic converter is the most restrictive part of the exhaust system, aftermarket catback exhausts have minimal gains unless you have a race header, or change to a high flow cat or test pipe. a race header and exhaust would provide similar gains to hondata, in the mid and high end, but would be louder, harder to install, and would cost more than $600. do exhaust after hondata.
Old Mar 3, 2004 | 10:49 AM
Reborn's Avatar
Reborn_
i believe my dealership supports hondata, so im guessing they can include it in the warranty or something, ask ur dealership
Old Mar 3, 2004 | 05:38 PM
BLaCk-S's Avatar
sounds good. whats "within reason"? dont hit 8600 every shift everytime? is that what u mean? if i hit 8600 sometimes is ok right? im just so paranoid im gonna f*ck my car up
Old Mar 3, 2004 | 08:30 PM
well, you really don't want to hit the limiter before you shift anyhow, so if you shift at 8400 or 8500 rpms once in awhile, you'll be alright. btw, the rev-limiter will not stop damage caused by a miss-shift, so don't make a mistake at high rpms.
Old Mar 4, 2004 | 01:55 PM
prospeed's Avatar
Default Re: (alohasurftoad)
All of our customers have been happy with the Hondata upgrade. We haven't had any problems with it yet!
Old Mar 9, 2004 | 06:55 PM
TwoSaints's Avatar
Default Re: (prospeed)
so the flash system is a k-series thing? new to hondata, just ordered an s200 system
Old Mar 9, 2004 | 07:02 PM
DC5ITR329's Avatar
Default Re: (EGCoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGCoupe &raquo;</TD></TR><TR><TD CLASS="quote">so the flash system is a k-series thing? new to hondata, just ordered an s200 system</TD></TR></TABLE>
that is correct.
08k20si
Honda Civic (2006 - 2015)
Jun 15, 2008 04:43 PM
ARMANDO_RSX
11
Sep 13, 2007 06:16 AM
03RSXTypeS
16
Mar 29, 2007 08:24 PM
Slow as piss
Oct 19, 2005 12:42 PM
christoble
Dec 6, 2004 10:22 AM
