Identity Crisis : identify stock ITR head....
Old Mar 3, 2004 | 04:46 AM
who00knows's Avatar
Default Identity Crisis : identify stock ITR head....
The exhaust cam has a C on it and the intake cam has a J on it.
Are these silver marks above the retainers normal????
Overview
Power Enterprise y0! ( Im assuming....this is what got me started on the whole thing....why have one of these with a stock valvetrain)
Stock Cam Gears.....
Retainer.....
HKS Plugs...BADDA BLING
Old Mar 3, 2004 | 05:13 AM
1 2 NV's Avatar
Default Re: Identity Crisis : identify stock ITR head.... (who00knows)
this was covered last week. u need to look at the cams for identifying marks (ie the rings around the end of the cam) then look at the distributor cam holder for some green paint. it may or may not b there, it does wash off with superclean and or simple green. i know because mine did. lastly look at the color of the paint on the valve springs. search though and u will find ur answer.
Old Mar 3, 2004 | 05:37 AM
who00knows's Avatar
Default Re: Identity Crisis : identify stock ITR head.... (1 2 NV)
thanks...i searched...I only saw blue paint on the exhaust valve springs..........no green paint anywhere......
Old Mar 3, 2004 | 06:23 AM
badCRX's Avatar
New User
yellow valve springs on the other side of the head.
Old Mar 3, 2004 | 06:26 AM
6SPD_EK's Avatar
blue on the exhaust springs = ITR yellow on the intake springs = ITR...do you see any signs of green paint near the dizzy on the head? to identify cams if OEM
The intake ports should have a lighter shade of silver, from being ported as seen here:
and as stated above there is a dab of green paint where the distributor mounts to the ITR head, but this isn't a sure way of telling either, because the paint can be washed/rubbed off. (can be seen from looking at the top of the head towards the back (intake manifold)
"PR3-x WILL NOT DESIGNATE AN ITR HEAD"
The PR3-1,2,3,4, etc. is a shared part number between ITR & B16A heads. It is NOT a sure way of distinguishing an ITR from B16 head, at all.
info from KATMAN
Modified by adirondackR at 7:58 AM 3/4/2004
Old Mar 3, 2004 | 08:21 AM
GSRswapandslow.
Guest
Posts: n/a
just gimmie an HKS sparkplug allready
but, take out the cams....check them
Old Jul 16, 2007 | 02:33 PM
SiR Inspired ED7's Avatar
Bringing ths back-up from the dead, My friend is selling an itr head it has the intake manifold and tb. I havent looked into the valve springs in other words the internals. I was reading that they have diffrent cam caps than the b16 head, Is this true? If so whats the diffrence in the cam caps because I want to determine if it is a real itr head.
Old Jul 16, 2007 | 03:27 PM
DonF's Avatar
Default Re: Identity Crisis : identify stock ITR head.... (SiR Inspired ED7)
Not cam caps, cam rails. Early B16 are cast "r"'s are forged likr GSR's.
Old Jul 17, 2007 | 11:56 PM
MikeSarr_GSR's Avatar
Default Re: Identity Crisis : identify stock ITR head.... (DonF)
thats an interesting tidbit of info
Old Jul 18, 2007 | 12:57 AM
AllMotorRandy's Avatar
Default Re: Identity Crisis : identify stock ITR head.... (MikeSarr_GSR)
I believe true ITR heads have the bowls ported on the intake side from the factory.....
They also have lighter weight valves. Notice how they're thinner towards the big end of the valve.......
Hope this helps!
moonman
May 23, 2009 07:43 AM
redzcstandardhatch
Sep 16, 2006 07:33 PM
who00knows
Mar 3, 2004 11:47 AM
