Suspension between DA and DC ?
The components are not really interchangable, but you can get them to work.
To use springs off a DC or an EG you will need the front struts and front drop forks.
The diameter of the DC strut is larger so it wont fit in your DA fork. The perches
on the DA and DC front struts are at different heights. In the rear you can use
either the DA or DC strut.
Theres a write up on g2ic that explains this in detail.
In short, its not really worth it, they are totaly two different chassis... It's hard to
determine what a 2" DC drop will look like on a DA. Or vice - versa.
I've had some EG suspension components on my DA, but its sorta hit or miss. You
basically try it and see what it does.
eastbayrep
Jan 3, 2010 03:33 PM
