what is the type s cams valve adjustment specs and can the cams be used with stock valve springs on
Old Mar 3, 2004 | 01:57 AM
superturboprelude's Avatar
Default what is the type s cams valve adjustment specs and can the cams be used with stock valve springs on
what is the type s cams valve adjustment specs and can the cams be used with stock valve springs on h22a?
Old Mar 3, 2004 | 03:23 PM
PirateMcFred's Avatar
Default Re: what is the type s cams valve adjustment specs and can the cams be used with stock valve springs
I would not try it. unless you stay well away from redline. lift on the type s intake cam is about .475 or 12mm. that is more than crower stage 2 which recomends springs. Try it and see. but post the nasty pics when it blows up, we all love that so much. if you have the engine and head all apart spend the extra $150 for titanium retainers for a little assurance but I would blow the $250 for springs.
the Pirate
Old Mar 3, 2004 | 03:39 PM
@ries's Avatar
It's like I told you before... the valve adjustment specs are the same as stock H22A cams (0.15-0.19 mm INTK & 0.17-0.21 mm EX).
qais_vtec
28
Jul 26, 2012 06:31 PM
99fbpem1
Jun 10, 2009 07:10 PM
Home Wrecker
Aug 18, 2006 05:50 AM
dc5r2002
Jun 16, 2004 03:41 AM
fastfu
May 5, 2003 11:38 AM
