o2 sensor wire from ecu on 97 gs-r?
anyone know which wire is for the o2 sensor from the ecu on a 97 gs-r? I'm installing my autometer a/f gauge. I can't find a good post from the search. Thanks.
Look on Apex's website at the V-AFC wiring diagram. It taps into A/F, doesn't it? If you can't find it, I'll pull out my Helms when I have more time.
(jumps for joy!) I CAN HELP I CAN HELP!!!
when i was wiring in my A/F guage.......on the Civic Si at least, its the BIG *** white one, its thicker then all the others, and if you follow it up from the ECU, it eventually gets protected by an orange casing, but its a solid white wire that is noticably thicker then the rest
tekstyle
Mar 24, 2004 05:39 PM
Honda Type R
Aug 18, 2003 09:47 AM
