gsr internals in a ls block
Old Mar 2, 2004 | 05:38 PM
lsvtec hatch05's Avatar
Default gsr internals in a ls block
i have all gsr internals in a ls block. the motor is not together yet and i am having crank spinning problems. my questions is does anybody on here have or know anybody that has gsr internals in a ls block? everybody i talk to has a different story so i am trying to find people on here that have done it or know people that have done it. anything will help me
Old Mar 2, 2004 | 06:06 PM
polymath's Avatar
Default Re: gsr internals in a ls block (lsvtec hatch05)
I really good friend of mine is doing just that. As long as you use ALL the components - rods, crank, pistons - it will work.
Old Mar 2, 2004 | 07:29 PM
fearless_dsm's Avatar
ive got the exact setup...all parts(crank,rods,pistons)are gsr...you can use type r rods and pistons,or ctr pistons...fits perfect
Old Mar 2, 2004 | 09:12 PM
Default Re: gsr internals in a ls block (fearless_dsm)
did you guys use ls main bearings or gsr?
Old Mar 2, 2004 | 09:16 PM
polymath's Avatar
They should all be the same (mains)...the all have PR3 part numbers i believe.
Did you check clearances, or just slap the same colors back in?
Old Mar 2, 2004 | 09:19 PM
Default Re: gsr internals in a ls block (Coyote1800cc)
what do you mean colors? i basically just slapped em back in, we are gonna check clearance tomorrow
Old Mar 2, 2004 | 09:27 PM
polymath's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lsvtec hatch05 &raquo;</TD></TR><TR><TD CLASS="quote">what do you mean colors? i basically just slapped em back in, we are gonna check clearance tomorrow</TD></TR></TABLE>
The Honda color-coded bearing system...did you just reuse the bearings?
Always get new bearings and check the clearances...
You didn't try to spin it a whole lot, did you?
Old Mar 2, 2004 | 09:31 PM
they are brand new bearings, the problem is my crank won't spin at all. it is probably clearance issues
Old Mar 2, 2004 | 09:33 PM
polymath's Avatar
check 'em all to be safe...rods and mains.
Old Mar 2, 2004 | 09:34 PM
this may sound like a dumb **** question, but how would you fix clearance issue?
Old Mar 2, 2004 | 09:52 PM
CleanHatch's Avatar
thicker head gasket.
Old Mar 2, 2004 | 09:53 PM
Default Re: gsr internals in a ls block (CleanHatch)
i am talking about clearance of the caps that hold the crank on and the crank because the crank is not spinning freely. right now the block is bare and i am trying to get the crank to spin without the rods connected
Old Mar 3, 2004 | 06:09 AM
did you put in the thrust bearings?i am using Ls mains and gsr rod bearings...ls thrust...ive used used bearings and had no problem as long as there not scarred or worn...i dont recommend it though because if i do and something goes wrong i dont want you blaming me...
Old Mar 3, 2004 | 04:38 PM
i am using aftermarket bearings, not stock honda bearings. my problem is the bearings are too thick. the guys that are running this set up, which bearings did you use so i know which ones to get
Old Mar 3, 2004 | 06:14 PM
polymath's Avatar
What's the thickness of the bearings you have?
Are you using the original paired block and crank? If so, check the bearing codes on the block and crank, get the appropriate sizes, and double check clearances. After you check clearances, go up or down in bearing size to get the right fit.
Or if you know the bearing sizes you have now, check the clearances and replace accordingly.
Old Mar 3, 2004 | 07:06 PM
Kataku2K3's Avatar
I would basically just start all over... For the mains get the alpha code off the block and take the numeric part off the crank... Once you have the alphanumeric code you can find which color OE bearing you would need... Once you have all of them mic your clearances... If everything is within the spec you are looking for then you're good to go, if not go up or down in thickness till you have your desired clearance... Should work just fine... This is Scott's (CrazyCompression's) street CRVTEC with B18C internals/girdle if you just wanna see pics (he originally was going to sell it so he could just have the money but his new FI motor is already setting him ~$30K so he's just going to run this motor this season)...
Specs:
Bottom End
B20B4
RS sleeved to 84.50mm
JE 84.50mm, 13.20:1 pistons
GSR crank* and girdle
Eagle rods* (GSR)
NEW Honda OEM mains & rod bearings, thrust washers (miced to NA tolerances)
NEW Honda OEM water & oil pump, main seal, and oil pan gasket
Spoon Sports baffle oil pan
ARP head studs
Golden Eagle 84.50mm headgasket
Golden Eagle VTEC oil feed kit
*balanced rotating assembly
Cylinder Head:
B16 (PR3), Port & Polished by Portflow
Bronze valve guides
REV flat face valves
Portflow dual valve springs
EF-1 retainers
EF1 M24E cams
STR adjustable cam gears
TWM 50mm individual throttle bodies
CLICK, More High Resolution Bottom End Pics
Old Mar 4, 2004 | 07:54 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Coyote1800cc &raquo;</TD></TR><TR><TD CLASS="quote">What's the thickness of the bearings you have?
Or if you know the bearing sizes you have now, check the clearances and replace accordingly.</TD></TR></TABLE>
no i am not running the paired block and crank. it is a gsr crank in a ls block
Old Mar 4, 2004 | 07:56 AM
Default Re: gsr internals in a ls block (Kataku2K3)
Kataku2K3 thanks for the help. imma try to trade the guy(who i bought them from) the ones i have no for the ones that i actually need. hopefully he will trade me because the bearings look like they still came out of the box. no scratches or anything in them
Old Mar 4, 2004 | 10:10 AM
Kataku2K3's Avatar
That sounds good, if you do go with OE bearings let me know if you need any help with colors, etc... Also I just realized you're located in Oregon, if you don't mind me asking where abouts... I'm from Gresham but I go to OSU so I'm down in Corvallis during the school year (except some weekends)... Good Luck
Old Mar 5, 2004 | 12:35 AM
JDMorgan's Avatar
so if i go buy bearings from honda how do i know which ones to get? i dont understand...
jordan2305
Dec 17, 2007 02:31 PM
allaboutdaz
Aug 19, 2006 10:56 AM
arielmalespin
Apr 27, 2005 11:24 AM
mrDFWmechanic
Apr 10, 2005 03:07 PM
trucdoken
Mar 12, 2005 09:37 PM
