camber kit question
Granted every car is different, I did not need a camber kit after I installed my S-tech's when I had them. My alignment specifications were still in range, although the rear was close to needing it. I'll find my alignment sheet and give you specific specifications later.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC5 03 »</TD></TR><TR><TD CLASS="quote">Granted every car is different, I did not need a camber kit after I installed my S-tech's when I had them. My alignment specifications were still in range, although the rear was close to needing it. I'll find my alignment sheet and give you specific specifications later.</TD></TR></TABLE>
cool thanks for that one
Yes, you will...
After I lowered my vehicle (03-RSX) the camber was way off, and the rear upper control arms mount vertically not horizontally like my old civic. So no shimming them.
FRONT CAM BOLTS
REAR UPPER CONTROL ARMS
FRONT CAM BOLTS
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GreenBean »</TD></TR><TR><TD CLASS="quote">Yes, you will...
Goes to show every car is different. If you want to play it safe, I'd go ahead and get the rear camber kit installed at the sametime, that will at least save you the cost of another alignment. I think -1.5 degrees is the maximum range for the rears, and you'll be damn close to that if not exceeding that w/ those springs. Off the top of my head, I'm pretty sure my rear camber measurements were -1.3LR and -1.2RR.
