Spoon open-ended lugs?
Old Mar 2, 2004 | 04:11 PM
ABTDer's Avatar
Default spoon lugs
did spoon ever make spoon open ended lugs?
thanks
Old Mar 2, 2004 | 05:06 PM
akeldama's Avatar
Default Re: spoon lugs (ABTDer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ABTDer &raquo;</TD></TR><TR><TD CLASS="quote">did spoon ever make spoon open ended lugs?
thanks</TD></TR></TABLE>
Yes.
Old Mar 2, 2004 | 06:11 PM
ABTDer's Avatar
Default Re: spoon lugs (glassjaw)
where does one get some?
Old Mar 2, 2004 | 06:15 PM
akeldama's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ABTDer &raquo;</TD></TR><TR><TD CLASS="quote">where does one get some? </TD></TR></TABLE>
A set comes through the classifieds every now and then. Other than that, I don't know.
Old Mar 2, 2004 | 06:39 PM
Willard's Avatar
red = closed
blue = open
silver = for OEM wheels
Old Mar 2, 2004 | 06:46 PM
Big Phat R's Avatar
IPS
Old Mar 2, 2004 | 06:47 PM
.RJ's Avatar
.RJ
Default Re: spoon lugs (Big Phat R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Big Phat R &raquo;</TD></TR><TR><TD CLASS="quote">IPS</TD></TR></TABLE>
Old Mar 2, 2004 | 06:49 PM
akeldama's Avatar
Default Re: spoon lugs (.RJ)
Aren't they backordered everywhere?
Old Mar 2, 2004 | 07:11 PM
Slow_Em1's Avatar
why would you want them
Old Mar 2, 2004 | 09:09 PM
R you serious's Avatar
Default Re: spoon lugs (Graditude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Graditude &raquo;</TD></TR><TR><TD CLASS="quote">why would you want them </TD></TR></TABLE>
extended wheel studs
Old Mar 4, 2004 | 09:19 PM
Slow_Em1's Avatar
Default Re: spoon lugs (R you serious)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by R you serious &raquo;</TD></TR><TR><TD CLASS="quote">
extended wheel studs </TD></TR></TABLE>
RRR U SERIOUS
Old Mar 4, 2004 | 10:27 PM
Kendall's Avatar
Earth.
Old Mar 5, 2004 | 05:07 AM
Misfit's Avatar
instead of commenting with that.. why not tell him why or why not he should get them.
&lt;-------Wants to hear the reasoning behind you comment. Educate me.
Old Mar 5, 2004 | 05:10 AM
.RJ's Avatar
.RJ
Default Re: spoon lugs (misfit)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by misfit &raquo;</TD></TR><TR><TD CLASS="quote">why not tell him why or why not he should get them</TD></TR></TABLE>
Why? They look good i guess. I bought some skunk2 nuts because they're longer.
You can get cheaper alternatives at pep boys/autozone/etc too, if you want to save money - I sure there are "OE" open ended lug nuts with a tapered seat (i know most mazdas use that type).
Old Mar 5, 2004 | 05:13 AM
Misfit's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">
You can get cheaper alternatives at pep boys/autozone/etc too, if you want to save money - I sure there are "OE" open ended lug nuts with a tapered seat (i know most mazdas use that type).</TD></TR></TABLE>
I agree with what you said.. I just wanted to know why he dosn't recomend them. That is all.
Old Mar 5, 2004 | 05:17 AM
.RJ's Avatar
.RJ
Probably because he thinks they are overpriced?
They probably are, but in the end you usually get what you pay for. The skunk2 lugnuts werent exactly cheap either.
RJ - done buying cheap chit for his cars that will just get tossed in the trash later
Old Mar 5, 2004 | 11:06 AM
Slow_Em1's Avatar
well the only reason i stated this is because spoon usually makes oem parts with an extra 100$ behind the pricetag. i was just curious as to why he wnated them is all.
Old Mar 5, 2004 | 03:06 PM
Saga's Avatar
Default Re: spoon lugs (Willard)
Open-ended = Old generation = Discontinued
Close-ended = New generation
Old Mar 5, 2004 | 06:08 PM
Tweakmeister's Avatar
Default Re: spoon lugs (Saga)
Personally, having open ended nuts (don't go there!)
stick with closed if you can (or long closed ones over long studs)...even if it adds a tiny bit of weight. I'm constantly cleaning the stud threads on mine and re-anti seizing them. Something that didn't happen with the closed ones.
Old Mar 9, 2004 | 08:21 PM
b18crx's Avatar
any web links?
Old Mar 9, 2004 | 08:23 PM
Hybrid ctr's Avatar
Default Re: spoon lugs (b18crx)
http://www.ipsracing.com/
Old Mar 9, 2004 | 09:38 PM
Rhetoric's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Saga &raquo;</TD></TR><TR><TD CLASS="quote">Open-ended = Old generation = Discontinued
Close-ended = New generation</TD></TR></TABLE>
What colors are the old generation (discontinued) ones? Just blue?
Old Mar 10, 2004 | 04:09 AM
Willard's Avatar
Default Re: spoon lugs (Rhetoric)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rhetoric &raquo;</TD></TR><TR><TD CLASS="quote">What colors are the old generation (discontinued) ones? Just blue?</TD></TR></TABLE>I have a set of blue (open) and 5 closed (red) that are a few years old.
Old Mar 10, 2004 | 08:04 AM
esponet's Avatar
willard, what brand studs are u using,
Old Mar 10, 2004 | 08:30 AM
thk's Avatar
thk
Members Only
Default Re: (esponet)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by esponet &raquo;</TD></TR><TR><TD CLASS="quote">willard, what brand studs are u using, </TD></TR></TABLE>
Those are ARPs.
