Anyone in the US or Canada with a real JDM SiR EF8 CRX??
Old Mar 2, 2004 | 02:43 PM
BillB's Avatar
Default Anyone in the US or Canada with a real JDM SiR EF8 CRX??
I'm after some aftermarket axels for my crx (A real jdm sir that came with a b16 stock & a Y1 tranny) over here in the UK we dont have anyone that builds uprated axels
As I'm running a B18 with jun cams & some semi slicks I'd like to uprate them to sumthing like the stage 2 gator axels or similar but will they fit?????????
I dont have ABL but I do have a Y1 with stock oem LSD if that makes any difference.
Thanks in advance
BillB
Old Mar 2, 2004 | 10:59 PM
BillB's Avatar
Default Re: Anyone in the US or Canada with a real JDM SiR EF8 CRX?? (BillB)
TTT
Old Mar 3, 2004 | 12:26 AM
91b16acrx's Avatar
just upgrade and look for da axels, im sure thers some race axles available for Da axles here in the us
Old Mar 3, 2004 | 09:21 AM
BillB's Avatar
Default Re: Anyone in the US or Canada with a real JDM SiR EF8 CRX?? (91b16acrx)
So DA teg axels fit??
Is that the 90-93 model by chance??
BillB
Old Mar 3, 2004 | 11:11 PM
BillB's Avatar
Bump
Old Mar 3, 2004 | 11:19 PM
91b16acrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BillB &raquo;</TD></TR><TR><TD CLASS="quote">So DA teg axels fit??
BillB</TD></TR></TABLE>
yea that is the 90-93 integra, and yest they will fit, and you can umpgrade yoru front hubs to da ones also
Old Mar 4, 2004 | 01:45 AM
iain's Avatar
b16 engined civics&crx's already come with those hubs (and knuckles and 262mm brakes) from the factory
Old Mar 4, 2004 | 01:55 AM
91b16acrx's Avatar
Default Re: Anyone in the US or Canada with a real JDM SiR EF8 CRX?? (iain)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iain &raquo;</TD></TR><TR><TD CLASS="quote">b16 engined civics&crx's already come with those hubs (and knuckles and 262mm brakes) from the factory</TD></TR></TABLE>
wow learned someting new
Old Mar 4, 2004 | 04:37 AM
crx_88_si's Avatar
http://www.raxles.com
Old Mar 4, 2004 | 07:06 PM
StorminMatt's Avatar
Not quite. SIR knuckles are different from 1990-1993 Integra knuckles. They are actually the same as USDM 1990-1991 Civic EX knuckles (although they DO use Integra brake hardware). Also, 1990-1993 Integra axles are not a direct replacement for the SIR. The SIR axles are actually a kind of hybrid axle, made from the inner joints from the 1990-1993 Integra and the outer joints/shafts from a 1986-1989 Integra. Use of these axles (or a high-performance replacement axle for the SIR) is preferable to the use of 1990-1993 Integra axles since use of 1990-1993 Integra axles requires removal of the dust seals on the knuckles. And this can't be the best thing to do. I believe Raxles makes a direct fit, high performance upgrade for the SIR and USDM B-series swaps.
Old Mar 4, 2004 | 11:01 PM
BillB's Avatar
Default Re: Anyone in the US or Canada with a real JDM SiR EF8 CRX?? (StorminMatt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StorminMatt &raquo;</TD></TR><TR><TD CLASS="quote">I believe Raxles makes a direct fit, high performance upgrade for the SIR and USDM B-series swaps.</TD></TR></TABLE>
So you think the b series swap axels for a CRX will fit, that would make sence i guess
I'm gona messure a spare set of sir axels i have then get the ppl from gator & raxels to check against what they make normaly.
Cheers for the info abt the joints that was the tricky bit to work out
BillB
Old Mar 5, 2004 | 07:59 AM
rsbad454's Avatar
i highly recommend the raxles axles.........they are totally NEW.......cost is 159 dollars U.S. per side.
Old Mar 5, 2004 | 08:22 AM
Targa250R's Avatar
be professional
Default Re: (crx_88_si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx_88_si &raquo;</TD></TR><TR><TD CLASS="quote">http://www.raxles.com</TD></TR></TABLE>
arusht
Jun 12, 2008 12:28 PM
hxtasy
Feb 22, 2005 06:38 AM
type Gendy
11
Nov 27, 2003 01:18 PM
ricodemus
Dec 4, 2002 06:28 AM
puffinrice
May 8, 2002 07:09 PM
