clean engine bays, how is it done?
Old Mar 2, 2004 | 01:37 PM
jbell's Avatar
Default clean engine bays, how is it done?
how the hell is this done? its AMAZING. i can easily see that things like the fluid reservoir are hidden, and the power steering and a/c are gone, but what else has been done to make them look so spotless?
Old Mar 2, 2004 | 02:18 PM
shorty91's Avatar
Default Re: clean engine bays, how is it done? (jbell)
hid the wires in the frame rails
clean the hell out of the block and tranny
Old Mar 2, 2004 | 02:43 PM
jbell's Avatar
Default Re: clean engine bays, how is it done? (shorty91)
do the wires for the fuse box and all that need to be extended?
Old Mar 2, 2004 | 04:02 PM
7808's Avatar
no ac. power stearing
Old Mar 2, 2004 | 04:26 PM
Kataku2K3's Avatar
Default Re: clean engine bays, how is it done? (fuctup)
First off both of those cars have paint jobs in which they sprayed the engine bay... Looks like it took care of most everything... The wiring looks factory to me but it is clean... I am extremely meticulous and don't like to see anything so whenever possible I run all the wiring through the chassis forward... This requires you to rip apart your interior/engine bay harness and add or pull wire as is needed to reach all your sensors/accessories (headlights, corners, horn, etc.)... It's worth it tho, clean engine bays make all the difference
Old Mar 2, 2004 | 05:57 PM
jbell's Avatar
Default Re: clean engine bays, how is it done? (Kataku2K3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kataku2K3 &raquo;</TD></TR><TR><TD CLASS="quote">First off both of those cars have paint jobs in which they sprayed the engine bay... Looks like it took care of most everything... The wiring looks factory to me but it is clean... I am extremely meticulous and don't like to see anything so whenever possible I run all the wiring through the chassis forward... This requires you to rip apart your interior/engine bay harness and add or pull wire as is needed to reach all your sensors/accessories (headlights, corners, horn, etc.)... It's worth it tho, clean engine bays make all the difference </TD></TR></TABLE>
hrm.. so you do add wire.
any pics of your bay?
Old Mar 2, 2004 | 06:11 PM
Kataku2K3's Avatar
Yea, you really do need to add a little as the wire takes a longer path running it through/under the chassis... I'll try to get you some pics this coming weekend when I head home from school... Kinda busy with midterms right now
Old Mar 2, 2004 | 06:16 PM
jbell's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kataku2K3 &raquo;</TD></TR><TR><TD CLASS="quote">Yea, you really do need to add a little as the wire takes a longer path running it through/under the chassis... I'll try to get you some pics this coming weekend when I head home from school... Kinda busy with midterms right now </TD></TR></TABLE>
i hear you on the midterms. how did you add the wire? cut+solder+wrap?
Old Mar 2, 2004 | 06:39 PM
Kataku2K3's Avatar
I try to find a place where the wire absolutely will not be seen, so yea normally I add it into the middle of the wire I'm extending, soldering all connections, and shrink wraping... Most of the time I don't use loom in these cases but I do wrap the wire with a solid band of electrical tape... It doesn't bother most people but I only use 3M Super33+ as it is super soft and deals with heat/weather extremely well... You can loom if you choose to do so...
Old Mar 2, 2004 | 06:40 PM
jdmDXrex's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jbell &raquo;</TD></TR><TR><TD CLASS="quote"> how did you add the wire? cut+solder+wrap?</TD></TR></TABLE>
yup
Old Mar 2, 2004 | 07:11 PM
TREVER's Avatar
Default Re: clean engine bays, how is it done? (jdmDXrex)
remove front engine and trans mounts. lower fuel filter to cross member.
Old Mar 2, 2004 | 07:29 PM
jbell's Avatar
Default Re: clean engine bays, how is it done? (TREVER)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TREVER &raquo;</TD></TR><TR><TD CLASS="quote">remove front engine and trans mounts. lower fuel filter to cross member. </TD></TR></TABLE>
you can remove those mounts?
Old Mar 2, 2004 | 08:26 PM
Kataku2K3's Avatar
Yea, I always do, they don't really do anything especially if you're running Hasports or something of the like...
Old Mar 2, 2004 | 08:41 PM
jbell's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kataku2K3 &raquo;</TD></TR><TR><TD CLASS="quote">Yea, I always do, they don't really do anything especially if you're running Hasports or something of the like...</TD></TR></TABLE>
to move a fusebox, do you have to cut and rewire each wire?
Old Mar 2, 2004 | 08:49 PM
jeremy.'s Avatar
beautiful
Old Mar 2, 2004 | 09:24 PM
92b16vx's Avatar
you can remove those mounts?</TD></TR></TABLE>
Not unless you have stiffer aftermarket mounts or inserts. I didn't have mine in for a while, and when I finally put them in it was a world of difference.
Old Mar 2, 2004 | 10:32 PM
dom93hatch's Avatar
My friend steam cleans his engine bay. That **** rocks. One hopes he would hook me up sometime with that service.
Old Mar 2, 2004 | 10:56 PM
slammed_93_hatch's Avatar
Default Re: (dom93hatch)
simple green owns the engine bay and if you seach ryanautry i belive did a kind of how to on hiding wires.
personally i **** with my car WAAYY to much to be hiding every, although its gota be clean and in order.
and the fact that my car is the only transportation i have, living out in the country with all the damn dirt roads off of the man roads engine bays' get toasted
Old Mar 3, 2004 | 12:30 AM
civicsitek GanGsTa's Avatar
Im confused....won't the tranny sag? Im running a h22 w/ place racing mounts and Id love to get rid of the tranny mount since it has already broken on me once.
Old Mar 3, 2004 | 02:09 AM
Fobtions's Avatar
Default Re: clean engine bays, how is it done? (civicsitek GanGsTa)
they are talkin about the mount right by where the ac compressor would be. on a b or d series.
in your case i doubt u have them anyways, since you got the H motor in there.
Old Mar 3, 2004 | 05:38 AM
7808's Avatar
Default Re: clean engine bays, how is it done? (Fobtions)
where the hell are the altenators? dont need those either?
Old Mar 3, 2004 | 06:50 AM
Daemione's Avatar
Both of those are using half-sized radiators, which opens up the front there. Of course, if you don't need the space, I think it's a silly on anything but a drag-only car.
And I think you'd be crazy not to use a tranny mount. Front mount, sure - that's fairly common, but you've gotta have something holding up the passenger side of the engine. Running 2 out of the 4 is just begging for the remaining ones to rip out of the frame & drop your engine to the pavement.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fuctup &raquo;</TD></TR><TR><TD CLASS="quote">where the hell are the altenators? dont need those either?</TD></TR></TABLE>
I noticed the exact same thing. But a battery has enough juice to get you around for a couple days if you have to, so pulling the alternator would be alright for a drag car or trailer queen.
Old Mar 3, 2004 | 07:46 AM
Icey112's Avatar
lets see some pics on how you ran the wires.
Old Mar 3, 2004 | 09:18 AM
PokeyD16Z's Avatar
Default Re: clean engine bays, how is it done? (Daemione)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Daemione &raquo;</TD></TR><TR><TD CLASS="quote">Both of those are using half-sized radiators, which opens up the front there. Of course, if you don't need the space, I think it's a silly on anything but a drag-only car.
I noticed the exact same thing. But a battery has enough juice to get you around for a couple days if you have to, so pulling the alternator would be alright for a drag car or trailer queen.</TD></TR></TABLE>
Aren't there 5 mounts? the left, right, and rear engine/tranny mounts and then the two smaller ones?
But, damn are those bays clean!!
Old Mar 3, 2004 | 10:22 AM
Kataku2K3's Avatar
Default Re: clean engine bays, how is it done? (92b16vx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92b16vx &raquo;</TD></TR><TR><TD CLASS="quote">I didn't have mine in for a while, and when I finally put them in it was a world of difference.</TD></TR></TABLE>
Not necessarily, I highly doubt that made that much difference as there isn't much too them... Yea, normally I don't install them (unless asked to) but with Prothane inserts or Hasports but if you don't run them with stock mounts your motor will "rock" just as much... Here's a test, if you're running stock mounts take off the two front lowers and go drive your car around, notice any difference with wheel hop, etc.? I really don't think you'd be able to tell... As for the pics, I'll get them up for you just as soon as I go back home this weekend (at school right now)... I've never tried relocating the under the hood fuse box but it too wouldn't be that big of a deal if you really wanted too... I can't tell with the EJ but the EH is still running it up front too...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicsitek GanGsTa &raquo;</TD></TR><TR><TD CLASS="quote">
Im confused....won't the tranny sag? Im running a h22 w/ place racing mounts and Id love to get rid of the tranny mount since it has already broken on me once.</TD></TR></TABLE>
Yea you can't do that, we're talking about the front lower mounts (aka torque or vibration mounts) as they really don't make much difference...
