i think i screwed up again!
damn my bro told me i could fill my mtf in this hole right here. i put in about 1qt
and now when i drain not even half a qt came out. i didnt start my motor so that maybe why all the mtf didnt come out. so is it ok to fill my mtf throught that hole?
I use that hole also, its MUCH easier since you dont have to bend a tube into a horizontal hole.
Drive the car and the fluid will settle. When you pour through there it goes right on the gears so a lot of it is still dripping off the gears thats why it reads low.
well i put in about 2.5 qts when the filler started to spill out some mtf so thats when i knew it was full. went i first empted it out there was only about 1qt that came out. the tranny makes a weird noise now when i let go of the clutch, it might be the flywheel but i didnt make that sound before. also it isnt as smooth as i though it would be, all well. so what would you guys think is makin that noise?
JDMfrontedLS
17
Jun 23, 2006 11:08 AM
sting94112
Feb 22, 2004 01:38 PM
FourthGenHatch
14
Apr 15, 2003 11:18 AM
