Engine managment
Ok I decided to go with a custom turbo setup for my 2000 si. Ive got the basic setup: Turbonetics ball bearing T3/T4 tubo, spearco intercooler, cast iron manifold. 35mm Tial Wastgate, HKS seq. blowoff valve, 440cc injectors and other piping and hardware. Now my problem is the engine managment. Can anyone tell me a good reliable product for the fuel and engine managment? The car is daily driven and will see no more than about 9 psi. I will be using stock compression and upgraded cams, cam gears, valve springs, and valves.Thanks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_MShue »</TD></TR><TR><TD CLASS="quote">check out uberdata
Huh!?!
http://www.hondata.com
</TD></TR></TABLE>Huh!?!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spade »</TD></TR><TR><TD CLASS="quote">
Huh!?!
http://www.hondata.com</TD></TR></TABLE>
well the only reason I say uberdata is because i've been looking into it a lot for when I go turbo. All you gotta have is a socketed obd1 ecu, a chip burner, and some chips. Also if you can't find someone with a widebando2 you would have to get one of those for tuning. It basically does all the same stuff hondata does...just that its free besides the burner and anything you need for tuning. If you plan on getting someone else to tune your care then i guess hondata would be the best thing...it just so damn expensive and i'm poor
Huh!?!
Navy_CRX
Honda S2000
Dec 22, 2010 02:30 PM
I know what you mean man.
