Schaeffer Gear Oil Transmission Synchromesh Syncromesh Fluid Gear Grind
Old Mar 2, 2004 | 09:04 AM
All-Motor H22A's Avatar
Default Schaeffer Gear Oil Transmission Synchromesh Syncromesh Fluid Gear Grind
Has anyone tried the Schaeffer 267 Moly Supreme Gear Lube before?
http://www.schaefferoil.com/se...e.htm
Here is a small independant review about this product.
http://www.bobistheoilguy.com/...s.htm
Right now I'm using GM Synchromesh. Although it took away the dreading 5th gear grind on the H22A, my 3rd gear still grinds slightly. But so far, Syncromesh helped my tranny a lot!
Old Mar 2, 2004 | 11:16 AM
doublejz's Avatar
Default Re: Schaeffer Gear Oil Transmission Synchromesh Syncromesh Fluid Gear Grind (All-Motor H22A)
i know in a b16 tranny, it sucks. When its cold out, its hard to shift until the fluid warms up some. I stick with gm sychromesh
Old Mar 2, 2004 | 12:00 PM
Default Re: Schaeffer Gear Oil Transmission Synchromesh Syncromesh Fluid Gear Grind (doublejz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doublejz &raquo;</TD></TR><TR><TD CLASS="quote">i know in a b16 tranny, it sucks. When its cold out, its hard to shift until the fluid warms up some. I stick with gm sychromesh</TD></TR></TABLE>
The same thing happens with GM Synchromesh. Because the fluid is thicker, for my car w/ GM Synchromesh, it's hard to shift. When the car warms up, the shifting is slick and smooth.
Old Mar 2, 2004 | 02:35 PM
doublejz's Avatar
gm synchromesh is pretty light weight compared to 80w-90 or 95w-90
deejae
Nov 16, 2013 02:39 PM
The Phil
Mar 18, 2005 08:27 AM
elevatethis
41
Nov 24, 2003 12:02 AM
Brian-Brian
May 18, 2003 09:31 PM
robbin
Oct 29, 2002 09:08 AM
