Has anyone swapped Integra Front LCA's into thier 99-00 SI?
Old Mar 2, 2004 | 07:55 AM
Full-Race Henry's Avatar
Default Has anyone swapped Integra Front LCA's into thier 99-00 SI?
Hey, has anyone installed integra front lca onto their 99-00 civic si? The bushing and bolt that connects to the rear crossmember on the Si is different than the one off of the integra. Have you or do you know anyone who has swapped em?
Old Mar 2, 2004 | 08:48 AM
95civicracer's Avatar
why are you doing this i don't understand
Old Mar 2, 2004 | 08:53 AM
Takeoff's Avatar
Default Re: (95civicracer)
I am not absolutely sure, but I don't think they are compatible.
I am guessing you want to change the front lca's so you can add a traction bar? If you want to add a traction bar you will need the 96-00 ex lca's & shock forks. You will also need to fab some new end links for your sway bar because they mount differently. Someone on this site makes some. Its either that or you switch to some other sway bar that fits and ex.
Old Mar 2, 2004 | 07:26 PM
ironcheftony's Avatar
they will not work because of the different hole sizes, just compare it, it can work if u drill the hole bigger
rexman2002
Suspension & Brakes
Jul 6, 2009 11:12 AM
Thirty-Nine
Oct 16, 2006 07:25 AM
B18C1SI
May 5, 2006 02:24 AM
JOHN WAYNE
Suspension & Brakes
May 7, 2005 07:47 AM
Mr. Choi
Aug 5, 2003 01:33 PM
