Have anyone install a GSR front sway on an EK?
Old Mar 2, 2004 | 07:27 AM
jimmhatch's Avatar
Default Have anyone install a GSR front sway on an EK?
If anyone who have done this, what parts do you need in order to make to put the swaybar on? Is it possible to put a GSR front swaybar on an EK?
Old Mar 2, 2004 | 08:34 AM
frankgrimes's Avatar
Default Re: Have anyone install a GSR front sway on an EK? (jimmhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jimmhatch &raquo;</TD></TR><TR><TD CLASS="quote">Is it possible to put a GSR front swaybar on an EK?</TD></TR></TABLE>
yes
i've done it twice its real easy...on my ex there was even 2 indents where the swaybar holes needed to go...
edit...the only thing you need to modify (at least on a ex) is the elbow for the air box had this hard plastic side tube that i had to remove and plug ...not sure about dx...
Old Mar 2, 2004 | 02:41 PM
jimmhatch's Avatar
Default Re: Have anyone install a GSR front sway on an EK? (frankgrimes)
thank you very much, but how about a DX?
Old Mar 2, 2004 | 02:46 PM
tougeEGsies's Avatar
DX you need new lower control arms like off an ex,lx. Because they came with front sway bar.
DX lca's don't have the mounting point for the sway bar, but there are aftermarket kits that bolt up to dx lca's.
I only had an issue with my shift linkage touching the sway bar.
Old Mar 2, 2004 | 08:22 PM
jimmhatch's Avatar
Default Re: Have anyone install a GSR front sway on an EK? (909 Civic)
what if you have the GSR lca's?
Old Mar 3, 2004 | 07:40 PM
jimmhatch's Avatar
anyone?
Old Mar 5, 2004 | 12:14 PM
The integra lca's bolted up to your civic?
P.S.
The sway bar rocks, tried it out last night the car feels way better.
Can't wait to get larger set up off type R.
SRC
Suspension & Brakes
Jan 23, 2011 12:38 PM
spoonfed*ek9
Suspension & Brakes
Aug 26, 2008 06:32 PM
spoonfed*ek9
Aug 25, 2008 01:27 PM
Propulsion
13
Jun 17, 2006 07:49 AM
lp3kr
Sep 11, 2001 05:35 PM
