Turbo People: How often change oil?
Old Oct 15, 2001 | 01:52 PM
leechungsr's Avatar
Default Turbo People: How often change oil?
1 What kit do you have
2 How often do you change your oil
3 Do you change it because it's black
thanks!
Old Oct 15, 2001 | 01:57 PM
liam821's Avatar
25 Year Member
Default Re: Turbo People: How often change oil? (LeeChun GSR)
i have a custom kit and try to change the oil every 3000 miles with 5w-30 castrol synthetic. Although in 3000 miles i normally add a few quarts of oil to the engine so it doesnt look that dirty by the time i change it..
Old Oct 15, 2001 | 02:01 PM
Rob03Pro5's Avatar
1.) Type of kits do not matter. All turbochargers need the same treatment to maintain a long life.
2.) It is said that turbo'd cars should have their oil changed every 2500 miles. Never go more than 3000miles.. this is critical.
3.) Never wait for oil to turn black regardless if you are turbo'd or not. Black oil suggests a dirty engine.. dirty engines decrease performance.. especially on turbo cars.
Just stick to changing your oil every 2500 miles. Use a Honda filter.. most other filters are crap. Some people say that using thin synthetic oil is great for turbos cuz the seal clearances in the turbo are small. This is a bad misconception. Turbo's generate alot of heat.. heat breaks down oil. Get a heavier set oil when turbocharging. If you prefer light oil, then change your oil VERY often.
Old Oct 15, 2001 | 02:09 PM
ArizonaTurbo's Avatar
I change my oil every 1500 - 2000 miles. I run my car hard at the track and it is a daily driver! I run Royal Purple motor oil and tranny fluid!
Old Oct 15, 2001 | 02:25 PM
leechungsr's Avatar
Default Re: Turbo People: How often change oil? (Rob92SC)
Im just curious on what people are running.
Old Oct 15, 2001 | 02:36 PM
TurboTypeR98's Avatar
New User
I try to change my oil every 3,000 miles and it is still pretty clean at this mileage. I have gone to about 4,000 miles and it was pretty dirty. By the way I use Mobil 1 10w30
Old Oct 15, 2001 | 05:49 PM
brcivic411's Avatar
Default Re: Turbo People: How often change oil? (TurboTypeR98)
same here. every 3K miles and mobile 1 10w30
Old Oct 15, 2001 | 06:02 PM
JM Performance's Avatar
Default Re: Turbo People: How often change oil? (brcivic411)
I'm gunna be turbo soon and plan on using Mobil 1 10w30 ever 2000 miles.
Old Oct 15, 2001 | 06:12 PM
SIK IN DA HED's Avatar
New User
Default Re: Turbo People: How often change oil? (00SilverLS)
actually... i heard its better to use synthetic motor oil when you have turbo...
Old Oct 15, 2001 | 07:56 PM
DragII's Avatar
25 Year Member
every 2500 to 3k I do Moble 1 10w 30
Old Oct 15, 2001 | 10:49 PM
austrian type-R's Avatar
Default Re: Turbo People: How often change oil? (DragIIcivic)
I change it every 8000 miles with Castrol 0W30, but I´m just supercharged
wantboost
Jan 27, 2015 01:28 AM
return_2020
11
Jan 5, 2005 05:42 AM
integraboi1010
Sep 15, 2004 11:31 AM
vtec.dc2
Jan 7, 2003 07:17 PM
mickey513
Oct 5, 2001 10:11 AM
