Jdm Dc SS 4-1 header + ctr/itr cams or An-r standard mild steel??
Old Mar 1, 2004 | 09:04 PM
cvrboi's Avatar
Default Jdm Dc SS 4-1 header + ctr/itr cams or An-r standard mild steel??
Need some input. Should I go with the the an-r header ($550) and make power in mid-upper range or go with the JDM dc ss 4-1 header ($350) and make power low-mid range with money left over to get a ctr/itr intake cam for about $150-200.
Car is daily driven b18c1 eg hatch
Mods include intake, 2.5 catback b-pipe with magnaflow muffler, skunk2 manni and ih8ricerz custom mild all motor chip.
Input would be greatly appreciated.
Old Mar 3, 2004 | 11:48 AM
BolivianDc2's Avatar
Default Re: Jdm Dc SS 4-1 header + ctr/itr cams or An-r standard mild steel?? (cvrboi)
if you want to end your modding at CTR cams, go w/ them
if you want to continue afterwards, go w/ teh ANR
Old Mar 11, 2004 | 12:35 PM
GSRCRXsi's Avatar
Default Re: Jdm Dc SS 4-1 header + ctr/itr cams or An-r standard mild steel?? (BolivianDc2)
i have a DC JDM 4-1 header, brand new, never installed for sale if you are interested. 300 shipped. its a great header.
edit, the header is ceramic coated
Modified by GSRCRXsi at 7:22 PM 3/11/2004
Old Mar 11, 2004 | 03:15 PM
1 2 NV's Avatar
if its daily driven i wouldnt buy anything but SS because mild steel rusts. down with the rusty header.
Old Mar 11, 2004 | 04:29 PM
crxracer2's Avatar
yea thats true unless u use high heat paint
Old Mar 11, 2004 | 11:36 PM
h22John's Avatar
I have the AN-R on my h22 eh3. Seems to make a good bit of torque below 4k rpm, after that I couldnt tell ya, need to get it tuned. Only gripe I have(should say we have, had 3 other friends helping install, heh) was that fitment was ***!!!, had to cut and install a 1 inch piece of pipe so that it would clear oil pan, also the upper flange was warped. BTW mine was a ss unit on a daily driven car with the street collector, ground clearance is not great but liveable.....................John
Old Mar 12, 2004 | 03:33 AM
GSRswapandslow.
Guest
Posts: n/a
i have an AN-R compact....and I LOVE IT. I do have the merge collector and ceramic coating...but, the header is awesome and kicked hte living **** out of the JDM DC i had!
btw, 191/132.4 with AN-R, AEM 3", 2.5" Crush bent exhaust...stock block, stock head
Old Mar 12, 2004 | 12:14 PM
yungfab's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cvrboi &raquo;</TD></TR><TR><TD CLASS="quote">Need some input. Should I go with the the an-r header ($550) and make power in mid-upper range or go with the JDM dc ss 4-1 header ($350) and make power low-mid range....... </TD></TR></TABLE>
is the an-r header 4-1 or 4-2-1? i thought that a 4-1 header made high end power instead of low-mid
Old Mar 12, 2004 | 08:41 PM
h22John's Avatar
Default Re: Jdm Dc SS 4-1 header + ctr/itr cams or An-r standard mild steel?? (yungfab)
AN-R=4-1
marc-111
Aug 15, 2005 08:01 AM
Suck my DX
May 28, 2005 03:53 PM
EM1SiR
Mar 5, 2004 05:21 PM
Speedz
Mar 31, 2003 05:20 AM
