maintanence required light...
Old Mar 1, 2004 | 08:29 PM
gsr_to_the_MAX's Avatar
Default maintanence required light...
does it go off every so many miles? or is there something wrong with my car?
should i worry bout it or jes reset it?
Old Mar 1, 2004 | 08:32 PM
LSTEG96's Avatar
Default Re: maintanence required light... (gsr_to_the_MAX)
search search SEARCH <U>SEARCH</U>
Old Mar 1, 2004 | 08:43 PM
chinaski's Avatar
the light goes off whenever you need to do a maintanence tune up. 30k, 60, 90k miles or something like that. theres probably nothing wrong, just turn the light off
Old Mar 1, 2004 | 08:48 PM
Kendall's Avatar
Or if you never want to worry about this problem again, you can pull the gauge cluster and remove the bulb.
Old Mar 1, 2004 | 08:56 PM
Sergei01's Avatar
its a light that flashes if u forget to change oil at 7500miles or 3000miles? no
Old Mar 1, 2004 | 08:59 PM
Kendall's Avatar
The light can't tell if you change the oil, it will come on regardless.
Old Mar 1, 2004 | 09:02 PM
LsNer00's Avatar
Default Re: (Kendall)
^word............jes turn it off dude.....or take the bulb out
Old Mar 1, 2004 | 09:30 PM
Vinhtran17's Avatar
Just Reset it.... just reach under your wheel with your right hand and just dig around like if your grabbing a chicks as.. soon enough you'll feel a button you can push in.... now "push it " and your light will soon go "kapoosh"....
Vinhtran17's Avatar
Oh yeah dont just push it.. push and hold it for like 5 seconds... lol (forgot to add that..)
Old Mar 2, 2004 | 07:47 PM
dubbedtodeath's Avatar
Default Re: (Vinhtran17)
the button is on the verry edge of the dash right on the lip towards the center console ... like above the gas pedal. its a small black rectangle box with a blue button. depress it while the car is at a idle till the light goes out. verry simple
Old Mar 2, 2004 | 07:56 PM
laseca's Avatar
Default Re: (dubbedtodeath)
I amazes me how many are too lazy to read the owners manual (if they have one) or simply do a search on the forum. This topic has been covered a BAZILLION times!
dohcredsol
Dec 9, 2007 09:10 PM
wardseg6
Oct 17, 2006 01:15 PM
Piercrg
Jul 11, 2004 05:40 AM
redteg1
Oct 14, 2002 04:40 AM
EGkTiOn_CiViC
Aug 30, 2002 05:51 PM
