AFC or Autometer Gauge? Whats right?
Old Mar 1, 2004 | 08:19 PM
SOFLSOL's Avatar
Default AFC or Autometer Gauge? Whats right?
Well to start this off. My autometer gauge sits right after the little box at 0vac/psi. At full throttle sometimes this gauge reads as much as 13-15psi. I'm running at 8psi. My AFC however usually reads at MAX .91 (9psi). What should I go by? I figure by now if I was really running 15psi my **** would be popcorn city. I dunno just kinda freaks me out sometimes.
Old Mar 1, 2004 | 09:07 PM
SOFLSOL's Avatar
Default Re: AFC or Autometer Gauge? Whats right? (SOFLSOL)
nobody?
Old Mar 1, 2004 | 09:23 PM
beepy's Avatar
Electronic or mechanical?
If electronic, did you get the 0-15 PSI sender or the 0-30?
If you mismatch them your reading will be waaay off.
Old Mar 1, 2004 | 09:27 PM
roydogg's Avatar
swap boost gauges with a friend or buy another one. If not that then buy a boost controller that also has boost readings. And if you mean "MAX .91" is that in bar? If so then your definately runnin more than 9psi.
Old Mar 1, 2004 | 09:40 PM
SOFLSOL's Avatar
Default Re: AFC or Autometer Gauge? Whats right? (roydogg)
Damn I said .91.. I meant .61 lol Thanks for catchin that prolly had abunch of people like wtf. And its a mechanical gauge. Unfortunatly dont really have any friends with one. Trying to get my friend to buy one for his saab and lemme test it first then install it in his car.
Old Mar 2, 2004 | 06:34 AM
SOFLSOL's Avatar
up? =\
Old Mar 2, 2004 | 08:04 AM
twkdCD595's Avatar
Default Re: (SOFLSOL)
whats the source you used for your boost gauge vac?
does it read correctly in vac? from what you can tell.
Old Mar 2, 2004 | 08:08 AM
SOFLSOL's Avatar
Default Re: (twkdCD595)
yeah vac is like 17-21 depending. My source is the fpr line.
Old Mar 2, 2004 | 08:33 AM
-Trinitron-'s Avatar
Well until you corrected the .91 to a .61 it made a little more sense. .91 is 13.3 lbs which would be close to the 15 lbs you are seeing on your gauge. Are you boosting that constantly or is it creeping up?
Old Mar 2, 2004 | 08:34 AM
SOFLSOL's Avatar
Default Re: (-TRINiTRON-)
I boost around 8 or a little below consistantly according to the afc. And on colder nights at higher rpm and full throttle I peak at .61 havent seen any over that.
skuded
Apr 21, 2011 04:38 PM
carrnut21
Jun 13, 2007 06:04 AM
LOwrestling2001
May 19, 2002 05:29 PM
threatcon13
Feb 3, 2002 01:23 AM
