doors popping
Old Mar 1, 2004 | 08:09 PM
Live_Love_Burn_Die's Avatar
Default doors popping
i am probably gonna have to just deal with it, but on my 89 CRX the things that hold the doors open pop when i open the door. i was wondering if there was a way to make it stop. i was thinking if i just took the pin out and pushed the thing back into the door then i would be fine. i can't get the pin out though, and i also would like to see if that would work before i do it.
thanks
Old Mar 1, 2004 | 08:12 PM
Kasper.'s Avatar
Default Re: doors popping (emanon5k)
lube them, and realign your doors.
Old Mar 1, 2004 | 08:32 PM
kid-honda's Avatar
Default Re: doors popping (Kasper-EF8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kasper-EF8 &raquo;</TD></TR><TR><TD CLASS="quote">lube them, and realign your doors.</TD></TR></TABLE>
That is the problem unless you got the too common door catch tear were the metal actually tears apart and if that happens its pretty much impossible to fix it permenetly.
Old Mar 1, 2004 | 08:33 PM
highhopes's Avatar
Default Re: doors popping (kid-honda)
what about welding another metal bracket reinforcing the torn metal? anyone solved this problem?
Old Mar 1, 2004 | 08:44 PM
kid-honda's Avatar
Its a hard place to get a good weld in but if you make a completely new bracket it can work pretty good.
Old Mar 15, 2004 | 07:25 AM
Default Re:
i fixed my problem i just took the pins out and now it doesnt pop anymore. just thought i would let you know
Old Mar 15, 2004 | 07:43 AM
kid-honda's Avatar
Was the metal torn?
Old Mar 15, 2004 | 08:05 AM
Default Re: (kid-honda)
yep
Old Mar 15, 2004 | 08:30 AM
IggDawg's Avatar
I have this issue too. I was going to have my friend go to town on it with an arcwelder. I but hey, if taking the pin out solves the problem I'll try that too.
Old Mar 15, 2004 | 08:31 AM
kid-honda's Avatar
Default Re: doors popping (IggDawg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IggDawg &raquo;</TD></TR><TR><TD CLASS="quote">I have this issue too. I was going to have my friend go to town on it with an arcwelder. I but hey, if taking the pin out solves the problem I'll try that too.
Just dont let the wind catch your door.
Old Mar 15, 2004 | 08:59 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kid-honda &raquo;</TD></TR><TR><TD CLASS="quote">
Just dont let the wind catch your door.</TD></TR></TABLE>
these don't hold the door closed all they are there for is to hold the door open when you open it if you are parked on a hill or something
so i don't see how letting the wind catch it would do anything but close the door back when you have it opened
Old Mar 15, 2004 | 09:10 AM
Therapy's Avatar
Default Re: doors popping (highhopes)
I had that done to mine - welded back in place...and the popping even with a new pin in place doesn't help...I also have brand new hinges and have the door perfectly aligned and I still get the noise. Unfortunately it seems to be something one just has to deal with.
Old Mar 15, 2004 | 09:44 AM
Default Re: doors popping (Therapy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Therapy &raquo;</TD></TR><TR><TD CLASS="quote">I had that done to mine - welded back in place...and the popping even with a new pin in place doesn't help...I also have brand new hinges and have the door perfectly aligned and I still get the noise. Unfortunately it seems to be something one just has to deal with.</TD></TR></TABLE>
take out your pins and push the thing back into the door, not all the way inside the door leave it hanging out enought to were you can pull it back out if you want to put it back together, and it will not pop any more and it will work just fine seriously, just listen to me.
Old Mar 15, 2004 | 09:45 AM
WickidSi's Avatar
When mine did that I took out the speaker in the door. With it out of the way you can unbolt the section that is within the door. That way it still functions as a catch, but without the two stage open and close. Kinda hard to explain but u will know when your are in the door.
Old Mar 15, 2004 | 10:42 AM
ScottEK's Avatar
Default Re: doors popping (WickidSi)
Having that pin out does allow the door to extend further though so you may run into problems with over-extending it and possibly damaging a fender or the door itself. I usually take that pin out to open up the door further to get to the top corner bolt on the fender.
Old Mar 15, 2004 | 12:51 PM
Riceburner247's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by emanon5k &raquo;</TD></TR><TR><TD CLASS="quote">
so i don't see how letting the wind catch it would do anything but close the door back when you have it opened</TD></TR></TABLE>
Imagine having the wind push the door open farther.
Swiftstar
Sep 29, 2008 08:19 PM
mmurphy
May 17, 2007 10:49 AM
japspecjohn
20
Aug 24, 2004 06:10 PM
N~FaMouSKhMerBoi
Dec 6, 2003 09:21 PM
PhucNguyen57
May 7, 2003 01:09 PM
