got dynoed here are the results
Old Mar 1, 2004 | 08:03 PM
silverlude001's Avatar
Default got dynoed here are the results
N/A http://www.angelfire.com/thefo...3.jpg
on 50 shot http://www.angelfire.com/thefo...2.jpg
Old Mar 1, 2004 | 08:07 PM
Mase's Avatar
Default Re: got dynoed here are the results (silverlude001)
you afr goes pig rich w/ the 50 shot, you arent making much power like that.
Old Mar 1, 2004 | 08:08 PM
Daboi630's Avatar
whoa.
hmm how about a more detailed list of mods? and I DONT KNOW a visit to my sig?
Old Mar 2, 2004 | 08:39 AM
Default Re: got dynoed here are the results (Daboi630)
mase, im not running rich on nitrous at all. the stoichemetric ratio for the complete combustion of nitrous and gasoline is approximately 9.7:1 and for N/A 14.7:1 so if anything im running rich off the bottle and just about right on spray.
Daboi630, my mods are found at http://www.angelfire.com/theforce/lude
visiting your thread as we speak
Old Mar 2, 2004 | 09:30 AM
Daboi630's Avatar
not to sound PICKY but how bout a resize boss?
Old Mar 2, 2004 | 09:49 AM
Mase's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by silverlude001 &raquo;</TD></TR><TR><TD CLASS="quote">mase, im not running rich on nitrous at all. the stoichemetric ratio for the complete combustion of nitrous and gasoline is approximately 9.7:1 and for N/A 14.7:1 so if anything im running rich off the bottle and just about right on spray.
um not quite dude.
Look at your power curve, its greatly increasing until all of the sudden you go extremely rich, you're not making much power. your afr should be steady at 12:1.
Old Mar 2, 2004 | 10:24 AM
'99luder's Avatar
woah.. you're running on a stock header?
Old Mar 2, 2004 | 10:33 AM
racekar's Avatar
i made only 179 whp with aem cold, msd, aem pullies, car sound 2.5 cat, and dc cc header, and apex ws exhaust, how come your make so much with so few mods?? oh i forgot and a tuned apex vtec controller dyno tuned!
Old Mar 2, 2004 | 10:34 AM
Default Re: (prelude97)
yup stock header prelude97 dont have the money for a mugen right now =/
mase where did you aquire 12:1 be stoich for nitrous and fuel. again stoich for fuel and nitrous is aprox 9.7:1
anyhow +59whp and +132wtq from a 50 shot and u say im not makin any power like that i dont know what kinda nitrous kits your comparing htis too.
Old Mar 2, 2004 | 10:36 AM
racekar's Avatar
Old Mar 2, 2004 | 10:38 AM
Default Re: (dchung1)
good break in i guess dont know what to tell you. my odometer reads 27k miles young and babied everyday
Old Mar 2, 2004 | 11:29 AM
graphic's Avatar
Default Re: (silverlude001)
i'm still trying to fathom...how you made 132 wtq off a 50 shot...
Old Mar 2, 2004 | 12:01 PM
Default Re: (boost-stupid)
hondatuning installed an nx kit on a stock sohc civic and made 110 wtq from a 50 shot
http://www.hondatuningmagazine.com/tech/0203ht_nx/
btw anybody know if the act xtreme clutch is any good?
Old Mar 2, 2004 | 12:20 PM
Mase's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by silverlude001 &raquo;</TD></TR><TR><TD CLASS="quote">yup stock header prelude97 dont have the money for a mugen right now =/
anyhow +59whp and +132wtq from a 50 shot and u say im not makin any power like that i dont know what kinda nitrous kits your comparing htis too.</TD></TR></TABLE>
I think you're confused here.
First of all, Under Load(Full throttle for instance), your motor should never be above 13.5:1 afr. otherwise its too lean.
Now at cruising loads, you want your car to run 14.7:1 or higher to improve your gas mileage.
with that being said, you should neglect whatever you heard about running a 9.7:1 afr.
Im not sure where you got the number 9.7:1 is stoich for nitrous/fuel, i dont know and dont care.
Point is, When you activate nitrous, you have your nitrous (which is an oxidizer) and you have your fuel and air.
Furthermore, I can bet you $$$ you are losing power due to the rich conditions.
Old Mar 2, 2004 | 12:42 PM
PrecisionH23a's Avatar
Default Re: (Mase)
ACT clutches are great, I run one in my car which is quite powerful.
As far as this is concerned:
Your A/F is totally fucked. You have nitrous yes, but you are still running gasoline... not methanol, ethanol, or alcohol... all of which have lower stoich numbers for a/f ratio's.
Most guys tune nitrous for a 12.0:1 a/f ratio for maximum potential.
You are just waiting to get ringwash arent you?
Old Mar 2, 2004 | 03:50 PM
H22A EG6's Avatar
Default Re: (PrecisionH23a)
nice numbers!
Old Mar 2, 2004 | 05:50 PM
LudeyKrus's Avatar
First off, how the HELL did you get that much torque from a 50 shot? It has to be a screw up....
Second off, you're running terribly rich (I just had to say it again ). 12.5:1 is where you wanna be when spraying.
Nice numbers! Looks like you really need to turn the VTEC xover down.
Old Mar 2, 2004 | 06:27 PM
yup ive noticed people smoothing out the vtec engagement by lowering it to 4500. not on the top of my list tho. a clutch is tho i dont know how long the stocker is gonna last with torque like this
as far as this debate on a/f goes again i know 14.7 is stoich for N/A i posted that at the top of this thread. but how can u think stoich burn for nitrous and gasoline is the same when the chemical make up of the mixtuire is completely different. there is 36% o2 by weight in nitrous as opposed to 20% in air. this is gonna throw all the calculations off. u can also find in Mike Kojima's honda/acura engine performance book in the nitrous ijection section pg 104. or u can click here i just found this online http://www.rx7.org/Robinette/nitrous.htm 4th paragraph down.
and finally nitrous express has put much R&D into designing there kits, if they can pull +61whp and +132 from a 50 shot and have a have that kinda fuel curve there has to be a reason for it. im not gonna start swappin out the fuel jet for a smaller one to tune my a/f on nitrous to anything less than where its at.
again the gains ive made, i think, are great for what it is and it seems to be in a very safe level. maybe if i had a built motor i would begin to tune my jets to my specific goals.
btw thank you all for the feed back keep it coming
Old Mar 2, 2004 | 07:34 PM
Icey112's Avatar
i dont think the hp is right or his tq way to high on a 50 shot.
Old Mar 2, 2004 | 07:49 PM
2000 honda's Avatar
not to bad
Old Mar 2, 2004 | 08:47 PM
homesauce's Avatar
Default Re: got dynoed here are the results (2000 honda)
I'm not positive, but doesn't a wideband measure oxygen content like an 02 sensor? if so, then ur A/F should still be 12:1 no matter what the actual chemical ratio is.
Old Mar 2, 2004 | 09:00 PM
graphic's Avatar
Default Re: got dynoed here are the results (homesauce)
132 wtq just sounds outragous from a 50 shot...
Old Mar 2, 2004 | 09:08 PM
NXLude's Avatar
Yeah, that torque is way off......but in all fairness I got 42 whp and 65 ft lbs from an NX 35 shot.....Ive got dynos from that.....
Old Mar 2, 2004 | 10:12 PM
sharkcohen's Avatar
Default Re: (NXLude)
WAY too rich, but from reading, he isn't going to listen.
Old Mar 3, 2004 | 05:42 AM
Default Re: (sharkcohen)
bottom line is with a fuel curve that rich nothing is gonna go wrong on nitrous. the power gains are good for what the shot is. so im gonna keep it that way till i get used to it and want more power. which is when i'll go ahead and spray a 75
homesauce u made a good point thanks
