Need advise from someone who has done the y8 intake manifold swap onto a y7!
Old Mar 1, 2004 | 05:51 PM
vi-RoadSailing's Avatar
Default Need advise from someone who has done the y8 intake manifold swap onto a y7!
I'm getting ready to get this swap done on my sedan with a d16y7 and the only part i dont have are the fuel lines and the connectors. What size fuel lines did you get and where did you get them. Also did you need to go under the car at all?
Old Mar 1, 2004 | 06:00 PM
sleepyhamsterlx's Avatar
Default Re: Need advise from someone who has done the y8 intake manifold swap onto a y7! (vi-RoadSailing)
As a matter of fact i just did it to my y7 this weekend, . It was easy just turning bolts, and a little extending of some of the sensors. Now youre going to want to use the y7 TB and plug up the other y8 TB's IACV mounts and holes with either a plate or something. And as far as the hoses, i went to a Plumbers Warehouse department, Home Depot sux, along with the other one( didn't have the right diameter and too expensive).
I had to go under the car to remove the mounting braket for the y7 manifold, and to bolt up the y8's IM middle bolt( that is bar far the worst bolt you'll deal with in this swap over. All in all, it was farely easy. and more questions?
OH, and one thing my new intake system from autozone(POS ) is rubbing against the Fuel line to the fuel rail, anyone with suggestions?
Old Mar 1, 2004 | 07:12 PM
do you only need one diameter of pipe? what about the large coolant line running to the left side of the im, do i have to extend that?
Old Mar 2, 2004 | 04:17 PM
Default Re: (vi-RoadSailing)
yeah youre going to have to extend both the main coolant hose in the back as well as the one on the left side of the Intake Manifold.
Old Mar 4, 2004 | 09:38 AM
thans for the help sleepyhamsterlx, but does anyone else have any advise about this swap?
jdmkid_82
Nov 25, 2008 06:19 AM
lunch_box_4_life
Oct 28, 2008 11:29 AM
92BlackSi
Jan 13, 2004 02:01 PM
