JG Luder
Old Oct 15, 2001 | 11:20 AM
cjb92's Avatar
Default JG Luder
I am sure you get this a lot but when you rebuild the bottom end on an h22a and you replace the pistons and rods. Do you need new sleeves put in there also due to some coating the stock pistons have or is that on h23 blocks only? Oh and could you email me the timing belt tensioner trick, thinking about milling .20 off an h22 head . thanks
Old Oct 15, 2001 | 11:30 AM
JG Luder's Avatar
Default Re: JG Luder (superflea)
Man, I still wouldn't mill it a whole lot, only to make sure its even and flat.
And yes, you have to re-sleeve it.
Old Oct 15, 2001 | 12:07 PM
cjb92's Avatar
Default Re: JG Luder (JG Luder)
well looking at the dyno charts on http://www.importreview.com under 2.2's There seems to be noticable gains with a milled head and mostly stock block. Could you maybe still email me the belt tensioner trick. Thanks.
stc876
Apr 22, 2016 12:38 PM
badassCRX
Mar 4, 2008 08:17 AM
Ls InTeGrA RaCeR
Nov 12, 2005 09:06 AM
thehatchninja
May 7, 2005 07:38 PM
brad_prelude
Dec 22, 2004 01:08 AM
