When good oil pumps go bad..A parents heartbreak
Old Mar 1, 2004 | 05:20 PM
earl's Avatar
Default When good oil pumps go bad..A parents heartbreak
This happened going into 4th gear and drove our car for several seconds at 8000 rpm wih no oil pressure.
Luckily we were using ACL bearings and they held up at high rpm with no oil. I put a few rod bearings in with the pump gears for you to see.
Old Mar 1, 2004 | 05:22 PM
infinatenexus's Avatar
LMAO.. I had the same **** happen to me.. excpet I spun two rod bearings spun...... I'll be ordering bearings to go with my piston/rods I got from you...lol
Old Mar 1, 2004 | 05:23 PM
CiH22vic's Avatar
What type of gear was that?
Old Mar 1, 2004 | 05:26 PM
lazerus's Avatar
Default Re: (CiH22vic)
looks good!!
Old Mar 1, 2004 | 05:27 PM
earl's Avatar
Stock gear..our first pass on alcohol
b16ahybrid's Avatar
wow, you got lucky.
Old Mar 1, 2004 | 05:28 PM
b18bturbo's Avatar
Default Re: (b16ahybrid)
time to move on up to wet sump or dry sump setup earl. i dont evne think the prodrive gear will last with meth for long time
Old Mar 1, 2004 | 05:29 PM
Smokinsax's Avatar
The Boot
DAMN! incredible...
Old Mar 1, 2004 | 05:35 PM
lazerus's Avatar
Default Re: (Smokinsax)
i think that alcohol made your oil pump drunk dryy sump.
Old Mar 1, 2004 | 05:36 PM
DaX's Avatar
DaX
Loved
Community Favorite
*still picking jaw up from table*
Old Mar 1, 2004 | 05:39 PM
Irishweird00's Avatar
Banned
Default Re: (Earl)
So................... I guess your saying its not good to run with no oil pressure at high RPM's
Old Mar 1, 2004 | 06:56 PM
Tinker219's Avatar
Default Re: (Irishweird00)
oh, oil pump gears are supposed to be 1 piece? Who'da thought...
Old Mar 1, 2004 | 07:22 PM
tegasaurus's Avatar
Default Re: (Tinker219)
just curious... what oil pump was that?
Old Mar 1, 2004 | 07:35 PM
hulkhb's Avatar
Default Re: (tegasaurus)
Old Mar 1, 2004 | 08:04 PM
275Performance's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tegasaurus &raquo;</TD></TR><TR><TD CLASS="quote">just curious... what oil pump was that?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Earl &raquo;</TD></TR><TR><TD CLASS="quote">Stock gear..our first pass on alcohol</TD></TR></TABLE>
Old Mar 1, 2004 | 08:17 PM
m R g S r's Avatar
Default Re: (275Performance)
How many miles were on it? I have a stock gsr oil pump with 70k miles, should I re-use for my 85mm b16, that with a prodrive gear or get a brand new oem gear?
Old Mar 1, 2004 | 09:10 PM
earl's Avatar
Default Re: (m R g S r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m R g S r &raquo;</TD></TR><TR><TD CLASS="quote">How many miles were on it?</TD></TR></TABLE>About 6 miles but they were very hard miles. Don't let this turn you off to a stock oem pump. They are great. To be honest, I will probably use another oem. Maybe we will put in some pro-drive gears..not sure until we find the absolute cause of the failure
Old Mar 1, 2004 | 09:12 PM
SOHCArchangel's Avatar
Default Re: (earl)
sintered metal = t3h sux0r
Old Mar 1, 2004 | 09:23 PM
TravSi's Avatar
Default Re: (SOHCArchangel)
is that some new engineering design your workin on for oil pumps all over the world?
Old Mar 1, 2004 | 10:00 PM
FredoSP's Avatar
Default Re: When good oil pumps go bad..A parents heartbreak (earl)
Old Mar 1, 2004 | 10:02 PM
rondigs's Avatar
Default Re: (TravSi)
For no oil pressure, those ACL bearings look pretty good. Could've been ALOT worse.
Old Mar 1, 2004 | 10:06 PM
pornstarSR's Avatar
Default Re: (earl)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by earl &raquo;</TD></TR><TR><TD CLASS="quote">About 6 miles but they were very hard miles. Don't let this turn you off to a stock oem pump. They are great. To be honest, I will probably use another oem. Maybe we will put in some pro-drive gears..not sure until we find the absolute cause of the failure</TD></TR></TABLE>
yeah im gona have to agree...oem oil pumps are good for almost anything..
like he said, it ran dry on oil. which could have been lots of things......it needs lube too, and it lubes everything else....so when it goes so does everything else
Old Mar 1, 2004 | 11:09 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: (pornstarSR)
vibrations from the flywheel. thats why it broke.
art
Old Mar 1, 2004 | 11:36 PM
tjbizzo's Avatar
Screw you guys, I'm... going... home.
Default Re: (Arturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Arturbo &raquo;</TD></TR><TR><TD CLASS="quote">vibrations from the flywheel. thats why it broke.
art</TD></TR></TABLE>
prease to exprain (please to explain)
Old Mar 1, 2004 | 11:39 PM
Kataku2K3's Avatar
Default Re: (tjbizzo)
Good thing your ACL's held up Time for a dry sump now?
