trying to fit ITR front sway bar on EK hatch...please help!
i've done some searching and found that the 99-00 Si front sway setup is the way to go, however...a friend has and ITR front sway bar, with endlinks and front LCAs..my question is...will this stuff work on my car? i have a 96 DX hatch. or do i need a beaks kit to mount the d collars?? and do i need different wishbones (the piece that connects the LCA to the struts)? thanks for any help!
oh yeah, and if this stuff doesn't work, what is the recommended upgrade path for sway bars on an EK?
to my knowledge this will NOT work at all...you can search "ITR front sway" archive topics in the eg+/delsol forum & every topic that shows up pretaining to a 96-00 civic says it won't fit....next please search & please stop bumping this thread (bumping here like once a day is okay - but this is NOT the classified furom where people tend to bump 3 to 5 times per day (not hour)) get the Si front sway bar swap IMO
Will not work! the sawy bar hits your shifter linkage. But the LCA's fit and all you need now is the sway bar. (end links work)
ransack
44
Oct 11, 2003 11:45 PM
