6mt?
ok i already searched, didnt find anything, maybe im using the wrong keywords, but wat does the 6th gear really do? i mean why is 6mt sports cars better than 5spd ones? sorry if its a dumb question but im tryin to decide between the type-s or a wrx....thanks in advance...
Most Hondas have a narrow rpm range where they make the most power, a 6 speed gear box has the ratios closer together so you can make better use of the power band. The downside is that you tend to shift more often.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kseriesDC5 »</TD></TR><TR><TD CLASS="quote">save some more gas on the freeway! goin 70 @ 3k rpm , 5 speeds.. 65 3k muahahah
cruise the streets in 6th
</TD></TR></TABLE>cruise the streets in 6th
"so theres no performance advantage wit da 6 spd?"
yes there is....its called, shorter gears = faster acceleration.......keeping the gears spaced right at the power band is what the 6th gear, much less, when you add a sixth gear all the rest of the gears are spaced closer together....
take for instance...the RSX type-s has the SAME final drive ratio as the civic Si... the gears are spaced closer together, to make it short, if the RSX type-s had a 7200 rpm cut off like the EP3 Si, they would both top out at the same speed....get me?
sorry, haha one more question, so a 5spd with overdrive is da same as a 6spd? i mean i kno da gear ratios are different, but im juss wondering if thats da basic idea?
you can go 70@3k because at 3K i'm only at 65/66mph... 6 speed is cool because of the faster acceleration but the 6th gear in the rsx i'm not too happy about it's too short for an overdrive...go any faster than 65-70 on the freeway gives poor gas mileage plus at the higher rpm lot's of noise
</TD></TR></TABLE>you can go 70@3k because at 3K i'm only at 65/66mph... 6 speed is cool because of the faster acceleration but the 6th gear in the rsx i'm not too happy about it's too short for an overdrive...go any faster than 65-70 on the freeway gives poor gas mileage plus at the higher rpm lot's of noise
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by texnteg »</TD></TR><TR><TD CLASS="quote">nope. its an overdrive.
the tremec t-56 has 2 overdrives. thats how a vette can get 35+mpg on the highway and still reach 170mph.</TD></TR></TABLE>
Are you takling about a C-5 vette with the 154mph limiter on it, What the hell kind of vette does 170?
the C5 isn't limited. it can reach 174.2 mph. the Z06 with a shorter final drive will reach about 155 mph. don't believe me? wonder over to http://www.corvetteforum.com or http://www.z06vette.com
my friend with a 405hp Z06 has reached 158mph(indicated) at texas world speedway near bryan, texas.
and the top speed record of the new C6 is 186mph. same tranny with a new 5th gear. and now, the windows won't pop out of the frame.
now, an automatic could be a different issue with top speed.
gray_civic_coupe
31
Nov 22, 2005 08:31 AM
