tach needle jumping when going over 4000 RPM??????
sup guys, I have a 91 CRX Si, and when I start stepping on it, the tach needle just jumps all over the place it's really annoying anybody had this problem before?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blaze45 »</TD></TR><TR><TD CLASS="quote">Or it could be your ignitor, I would replace it and see if that fixes it.... It did for me.... That sends the signal to your tach.
Blaze</TD></TR></TABLE>
Yup, most likely this. Before buying one (like $80-90) pop off your cap and check all the connections there, theres 4 wires held on by spade clips. Just make sure theyre snug.
I had the same problem, after replacing the ignitor and cap the tach was still bouncing. So i finally got around to changing the rotor and it solved the problem.
I would suggest changing the cap and rotor first, it's only like 20 bucks for both. If that doesn't work try a new ignitor.
Average Al
Jan 22, 2004 04:13 PM
