B16 SiR II Engine Swap In my EG next week!
Old Mar 1, 2004 | 03:21 PM
grandmasterflex's Avatar
Default B16 SiR II Engine Swap In my EG next week!
$2500 installed. Full complete B16A2 swap. YEA! Hydro tranny and all. I might add lsd later, but now I dont think I will (its an extra $300 is it worth it?). I can also add any options right now (racing clutch, new timing belt, ect. ect.) I was wondering what else I should get along with my swap. Also are aftermarket b series mounts way better than the ones they will be using?
Old Mar 1, 2004 | 03:23 PM
slammed_93_hatch's Avatar
Default Re: B16 SiR II Engine Swap In my EG next week! (whole9)
only 300 more for the lsd? get that **** then but ask what kind it is.
as for the others.
i would do a clutch, Pressure plate, resurface the flywheel if its needed, replace the timing belt, and water pump, its easy as hell when the motor is out.
Old Mar 1, 2004 | 03:25 PM
civicHBphtride's Avatar
lsd is worth it! and while they are putting the motor in a timing belt change would be good! if you can get a clutch get that too! it would suck if you put the motor in and find out the clutch is gone. oh and its a EG some steal braided clutch lines would be nice they are cheaper than factory lines! good luck! hope everything works out great!
Old Mar 1, 2004 | 03:34 PM
hatch4raceb16's Avatar
Default Re: B16 SiR II Engine Swap In my EG next week! (civicHBphtride)
GET THE LSD, I have lsd on my b16 sir2 and I can lauch the F outta it, lol. I can smoke my friends b16 without LSD. So go for it, do the waterpump, timing belt and clutch.
Old Mar 1, 2004 | 03:35 PM
hXc-DC2's Avatar
Default Re: B16 SiR II Engine Swap In my EG next week! (slammed_93_hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slammed_93_hatch &raquo;</TD></TR><TR><TD CLASS="quote">i would do a clutch, Pressure plate, resurface the flywheel if its needed, replace the timing belt, and water pump, its easy as hell when the motor is out.</TD></TR></TABLE>
What he said. You'll love the B16, people hate but it's a great motor.
Old Mar 1, 2004 | 04:28 PM
b16ahybrid's Avatar
Default Re: B16 SiR II Engine Swap In my EG next week! (SlowB16EF)
I wouldn't even put the motor in unless you replace the timing belt and water pump.
Definatly get the lsd, well worth the money spent (i'll be needing one and i'm lookig to spend about $900),
Clutch is a good idea too. What are your plans for the car? Bolt-on? boost ?
Old Mar 1, 2004 | 04:35 PM
zer0.'s Avatar
Default Re: B16 SiR II Engine Swap In my EG next week! (b16ahybrid)
you're a bastard,lol i just sold my LS swap saturday and will be getting my friend's 99 B16A2 swap for $2000 muhahaha,can't wait!
Old Mar 1, 2004 | 04:39 PM
Default Re: B16 SiR II Engine Swap In my EG next week! (zer0_2_6ixty)
Im thinking all motor for a while. Then maybe if I feel like, after I do some more suspension upgrades I will turbo. :D
Old Mar 1, 2004 | 05:24 PM
Formula 1's Avatar
sounds sweet i can get a b16 second shipping with lsd for 2400 so thats a nice deal
Old Mar 1, 2004 | 05:25 PM
b16ahybrid's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whole9 &raquo;</TD></TR><TR><TD CLASS="quote">Im thinking all motor for a while. Then maybe if I feel like, after I do some more suspension upgrades I will turbo. :D</TD></TR></TABLE>
Defiantly go with the b-series mounts then. When I did my swap, before installing it I filled my mounts with rtv silicone to make them solid. Cheap but effective way to reduce wheel hop. It cost me a total of $0.00 (free from work) and I'm glad I did it.
Old Mar 1, 2004 | 05:27 PM
bad93ex's Avatar
That is a great deal.
Get the LSD and do the things that other people have been saying. Preventive maintenance always helps.
Old Mar 1, 2004 | 05:38 PM
dpw41285's Avatar
Thats cheap installed!!!!!! Get the frickin LSD The problem with putting a new clutch and **** n is that the motor and tranny come bolted together and you mechanic may not want to dick with it for 2400. IF you do definatley get a flywheel them bitches are cheap on ebay. Throw in the clutch t-belt and pump, might as well get all the FREE labor you can.
Old Mar 1, 2004 | 05:49 PM
OBD1Kenobe's Avatar
Definately go with the LSD now. I love mine. If you decide you want an LSD later, it will be an expensive pain-in-the-***. Know what kind is being offered first though. A gear-type (such as Quaife) is stupid durable. A clutch-type (a la Kaaz) is sweet (I like the feel), but the clutch plates are subject to wear and require peroidic rebuilds.
Have the timing belt, tensioner and water pump replaced also. There is no room for debate on this one.
Enjoy your new power plant....
Old Mar 16, 2004 | 07:56 PM
SpoolinEK9's Avatar
From: Seattle/Ligonier, WA/PA, United States of Honda
i wouldnt sell my ls swap for a b16 swap lol 111lbs tq fun..
Old Aug 26, 2004 | 09:07 AM
92-LS-Civic's Avatar
Default Re: (SpoolinEK9)
what can you expect a 92 civic hatch with a b16 swap to run? thanks
Old Aug 26, 2004 | 09:12 AM
nsxmatt's Avatar
Default Re: (zdowell17)
Low 14's.
Old Aug 26, 2004 | 09:15 AM
Got Milk's Avatar
Default Re: (nsxmatt)
mid to low 14's depending on driver and wut model EH u have
Old Aug 26, 2004 | 09:39 AM
Cain Marko's Avatar
Rotary Lift Specialist
Default Re: (Got Milk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Got Milk &raquo;</TD></TR><TR><TD CLASS="quote">mid to low 14's depending on driver and wut model EH u have </TD></TR></TABLE>
and what kinda stuff you got inside the car, if its gutted then you will run a little faster, same goes for no ac/ps, im gutting my car for college, just so **** doesnt get stolen
halfakneegrow
Transmission & Drivetrain
Apr 15, 2014 10:23 AM
blasterman87
Aug 28, 2009 04:54 PM
Chiller
Feb 20, 2006 02:05 AM
