Do del sol seats bolt right up in a ek???
Old Mar 1, 2004 | 03:00 PM
KiNG $h!t's Avatar
Default Do del sol seats bolt right up in a ek???
Do del sol seats bolt right up in a ek??? thanx for ur help
Old Mar 1, 2004 | 03:02 PM
Turbo E's Avatar
no, you have to swap the EG rails onto the del sol seats
EDIT. oops you said EK. wrong forum then
Old Mar 1, 2004 | 03:03 PM
skip.two's Avatar
Default Re: Do del sol seats bolt right up in a ek??? (this guy 2fast)
yes they will bolt right up if you use the EK rails.
Old Mar 1, 2004 | 03:07 PM
KiNG $h!t's Avatar
thanx and sorry illuzionz and turbo e u are a offical dumbass this is the right forum for eks too
Old Mar 1, 2004 | 03:17 PM
deeksmooth's Avatar
Default Re: Do del sol seats bolt right up in a ek??? (jL iLLuZiOnz 9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jL iLLuZiOnz 9 &raquo;</TD></TR><TR><TD CLASS="quote">yes they will bolt right up if you use the EK rails.</TD></TR></TABLE>
tru, there have been plenty of posts on this, the last one i posted how to properly tighten the bolts down in order to keep the seat from squirming under hard acceleration and braking. since all the holes don't line up when you mount the EK rails to the Sol seats, "START" all of the bolts by kinda tweaking the rails a hair to get the bolts in. then tighten them down in this order.
FRONT OUTSIDE, FRONT INSIDE, REAR OUTSIDE, REAR INSIDE
also make sure you perfectly bend the wire underneath so its not too tight or too lose.
Old Mar 1, 2004 | 03:20 PM
PhreeStyleHB's Avatar
Default Re: Do del sol seats bolt right up in a ek??? (citrEK)
switch the rails. when i did this, my sol seats had 3 studs for nuts.. and the rails had 2 holes, so i had to drill another hole for the middle stud.
Old Mar 1, 2004 | 03:22 PM
deeksmooth's Avatar
Default Re: Do del sol seats bolt right up in a ek??? (PhreeStyleHB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PhreeStyleHB &raquo;</TD></TR><TR><TD CLASS="quote">switch the rails. when i did this, my sol seats had 3 studs for nuts.. and the rails had 2 holes, so i had to drill another hole for the middle stud.</TD></TR></TABLE>
drilling??? woah, that shouldn't be neccessary (sp?). there are two 3 bolts total that hold the EK rails on the sol seats... 2 on the bottom, and 1 on the backrest.
Old Mar 1, 2004 | 03:31 PM
Turbo E's Avatar
Default Re: (this guy 2fast)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by this guy 2fast &raquo;</TD></TR><TR><TD CLASS="quote">thanx and sorry illuzionz and turbo e u are a offical dumbass this is the right forum for eks too</TD></TR></TABLE>
you're welcome. mebbe the forum titles should be changed.
Old Mar 1, 2004 | 03:43 PM
deeksmooth's Avatar
Default Re: (Turbo E 604)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo E 604 &raquo;</TD></TR><TR><TD CLASS="quote">
you're welcome. mebbe the forum titles should be changed. </TD></TR></TABLE>
"EG+" means EG and up... including EK
its all good.
Old Mar 1, 2004 | 05:32 PM
95civicracer's Avatar
they don't bolt directly to my 95 ex coupe i know this for a fact not sure about you car though
Old Mar 1, 2004 | 05:41 PM
Ricey McRicerton's Avatar
Default Re: (95civicracer)
I JUST DID THIS 2 DAYS AGO!!!
Here's the deal.
You need to dissasemble both seats all the way down to the seatback portion and the butt cushion portion. Swap the WHOLE EK assembly onto the Sol seats and voila. If you need any help PM me!
Old Mar 2, 2004 | 01:00 PM
KiNG $h!t's Avatar
what about gsr seats will i need to switch the rails with those too??
Old Mar 2, 2004 | 01:08 PM
skip.two's Avatar
yes i would think so. never tried GSR seats, but i do know for sure about the del sol seats.
Old Mar 2, 2004 | 01:10 PM
Grimm's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by this guy 2fast &raquo;</TD></TR><TR><TD CLASS="quote">what about gsr seats will i need to switch the rails with those too??</TD></TR></TABLE>
stick with the del sols
the swap is very easy,
1)unbolt the rails (3 bolts per side apprx) off the ek seats.
2)unbolt the rails off the del sol seats.
3)bolt the ek rails to the del sol seats, one rail only uses 2 bolts not three like on the ek, obviously the one that you can't bolt is the one that dosen't bolt.
4) drink
Old Mar 2, 2004 | 01:16 PM
KiNG $h!t's Avatar
ight well thanx on the info on the delsols prob will stick with them but would liek to know about gsr seats also
Old Mar 2, 2004 | 01:27 PM
Grimm's Avatar
i'm pretty sure their very similar, most Honda seat parts are interchangeable.
Friend had leather GSR seats and hated them, too hot in summer, too cold in winter, too slippery in curves (no hug)... He changed to the del sols after about a year...
my only complaint is the thigh/leg bulsters are a bit small...
Old Mar 2, 2004 | 02:58 PM
Turbo E's Avatar
Default Re: (citrEK)
ah...I figures EG's AND delsol. my bad.
SovXietday
13
Apr 3, 2006 09:18 AM
Strictly_EK
Apr 5, 2005 09:47 PM
motohatch557
Dec 27, 2002 10:33 PM
MassRacingLab
Aug 29, 2002 11:06 PM
