power windows into my DX coupe please help with parts list...
I just got a new alarm and I want the power windows option... Can some one give me a parts list on what to shop for or a company who makes a kit... TIA!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92civeg »</TD></TR><TR><TD CLASS="quote">spal makes a complete kit</TD></TR></TABLE>
I used the spal universal kit and it was a pita to install + mount. I ended up ditching those and going with 94 ex coupe regulators in my hatch.
PARTS USED:
-both door panels from '93-95 ex coupe
-both window switches from '93-95 ex coupe
-both regulators from a '93-95 ex coupe
-both door wiring harnesses (for the regulators)
-electrical diagram of a ex coupe (preferably from the service manual)
-lots of wire, electrical tape, solder and patience.
I have a list of pinouts (what pin to what wire) on my comp, so if you seriously want to do that, then let me know and I'll post up the info.
-l8r
PARTS USED:
-l8r
Eh, I'll post up the info anyways.
Driver's Side window switch.
pins (looking from back of plug)
AB CD
EFGHIJ
A to passenger + (passenger switch pin.C)
B to passenger - (passenger switch pin.A)
C hot wire in (run from a 12v source thats hot when key is in on or acc. depends on how you want it wired) and put an inline fuse (I used a 20a fuse)
D not used
E ground #1
F hot input for passenger side switch
*I spliced it from the same wire as used for pin.C and put a 20a fuse here,
*Also note that this wire also goes to passenger switch pin.D
G this is for the auto-down feature
H driver's motor down (-)
I ground #2 (I spliced with E and set it to a good ground source)
J driver's motor up (+)
Passenger Side window switch.
ABCDE
A input from driver's switch pin.B
B passenger motor down (-)
C input from driver's switch pin.A
D hot wire input (from same wire used on driver's switch pin.F)
E passenger motor up (+)
That should be acurate, if any more questions, etc... lemme know.
-l8r
AB CD
EFGHIJ
D not used
E ground #1
ABCDE
-l8r
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Death Scythe »</TD></TR><TR><TD CLASS="quote">
PARTS USED:
-l8r</TD></TR></TABLE>
how much did you end up spending with this project?
PARTS USED:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Shaun »</TD></TR><TR><TD CLASS="quote">
how much did you end up spending with this project?</TD></TR></TABLE>
ditto A buddy of mine just totaled his 95 EX coupe So what do I need off the doors??
