power windows into my DX coupe please help with parts list...
I just got a new alarm and I want the power windows option... Can some one give me a parts list on what to shop for or a company who makes a kit... TIA! https://honda-tech.com/forums/images/smilies/emthup.gif
Re: power windows into my DX coupe please help with parts list... (civiksiracer1)
spal makes a complete kit
Re: power windows into my DX coupe please help with parts list... (92civeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92civeg »</TD></TR><TR><TD CLASS="quote">spal makes a complete kit</TD></TR></TABLE>
I used the spal universal kit and it was a pita to install + mount. I ended up ditching those and going with 94 ex coupe regulators in my hatch. PARTS USED: -both door panels from '93-95 ex coupe -both window switches from '93-95 ex coupe -both regulators from a '93-95 ex coupe -both door wiring harnesses (for the regulators) -electrical diagram of a ex coupe (preferably from the service manual) -lots of wire, electrical tape, solder and patience. I have a list of pinouts (what pin to what wire) on my comp, so if you seriously want to do that, then let me know and I'll post up the info. -l8r |
Re: power windows into my DX coupe please help with parts list... (Death Scythe)
Eh, I'll post up the info anyways.
Driver's Side window switch. pins (looking from back of plug) AB CD EFGHIJ A to passenger + (passenger switch pin.C) B to passenger - (passenger switch pin.A) C hot wire in (run from a 12v source thats hot when key is in on or acc. depends on how you want it wired) and put an inline fuse (I used a 20a fuse) D not used E ground #1 F hot input for passenger side switch *I spliced it from the same wire as used for pin.C and put a 20a fuse here, *Also note that this wire also goes to passenger switch pin.D G this is for the auto-down feature H driver's motor down (-) I ground #2 (I spliced with E and set it to a good ground source) J driver's motor up (+) Passenger Side window switch. pins (looking from back of plug) ABCDE A input from driver's switch pin.B B passenger motor down (-) C input from driver's switch pin.A D hot wire input (from same wire used on driver's switch pin.F) E passenger motor up (+) That should be acurate, if any more questions, etc... lemme know. -l8r |
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Death Scythe »</TD></TR><TR><TD CLASS="quote">
I used the spal universal kit and it was a pita to install + mount. I ended up ditching those and going with 94 ex coupe regulators in my hatch. PARTS USED: -both door panels from '93-95 ex coupe -both window switches from '93-95 ex coupe -both regulators from a '93-95 ex coupe -both door wiring harnesses (for the regulators) -electrical diagram of a ex coupe (preferably from the service manual) -lots of wire, electrical tape, solder and patience. I have a list of pinouts (what pin to what wire) on my comp, so if you seriously want to do that, then let me know and I'll post up the info. -l8r</TD></TR></TABLE> how much did you end up spending with this project? |
Re: power windows into my DX coupe please help with parts list... (Shaun)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Shaun »</TD></TR><TR><TD CLASS="quote">
how much did you end up spending with this project?</TD></TR></TABLE> ditto A buddy of mine just totaled his 95 EX coupe So what do I need off the doors?? |
Re: power windows into my DX coupe please help with parts list... (CivicSiRracer69)
Death Scythe: So you didn't need to use a floor harness or a window relay?
Re: power windows into my DX coupe please help with parts list... (left)
