B16A Hasport Problem
Old Mar 1, 2004 | 02:09 PM
B18C1_CRX's Avatar
Default B16A Hasport Problem
i just swaped my crx si with a b16a. heres the prob when i plug in the hasport subharness the car won't start. but if i take the ground off the vtec preasure switch the car will start, but it throws a code 22 which is the vtec preasure switch. can anyone tell why it is doing this? i used the stock crx si motor harness and doubled checked the pins in the ecu. thanks
Old Mar 1, 2004 | 02:30 PM
silverCRXTC's Avatar
Default Re: B16A Hasport Problem (B18C1_CRX)
maybe u have them wired backwords, the vtec switch and the ground backward?
The ground in the harness is supose to goto the chassis also (idk if u hooked up the ground to the vtec ground)
Old Mar 1, 2004 | 02:36 PM
paybac4223's Avatar
does it attempt to crank or turn over? or is it just dead when you turn the key?
Old Mar 1, 2004 | 04:46 PM
B18C1_CRX's Avatar
it attempts to crank just doesnt turn over
Old Mar 2, 2004 | 03:30 PM
B18C1_CRX's Avatar
Bump
Old Mar 2, 2004 | 06:25 PM
brian g's Avatar
When you put the VTEC wire in the A plug on the ECU, did you have an open hole or was there a wire already in it?
brian g
thundernoodle
Mar 25, 2013 05:01 PM
denraweb
Sep 14, 2007 12:00 AM
Rajin
Aug 9, 2007 11:55 AM
Freeko
Jul 25, 2006 07:51 PM
white91rex
Apr 20, 2005 10:31 AM
