PROBLEM, tranny is making hissing sound???
is all the time or just during acceleration/ decleration? Could be a missing tooth on the ring gear or pinion gear if it is all the time. Could be low in tranny fluid or have old unused tranny fluid. If it is just situational (the noise) then explain and I will offer more feedback
the tranny make noise wen i accelarate n just warm it up...i know i have 2 replace the bearing but i dont think thats the problem
are you using a racing clutch????
does it makes sounds when you step on the clutch???
if hissing goes away during acceleration and comes back while at idle
YOU GOT BAD TRANNY BEARINGS
well at least thats what happened to a tranny we had...
same symptoms.....usually due to aggressive clutches and low quality fluid or just low fluid
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkRiBLaH »</TD></TR><TR><TD CLASS="quote">you got the rare b72T 9 way-LSD-rattle snake tranny !!!!</TD></TR></TABLE>
I had one of those once
