ALTERNATOR FUSE KEEPS BLOWING! wheres the short???
my alternator fuse blows every time i hit v-tec. i looked at all the wires to the best of my ability, especialy my alt.,vss, and O2 wires. any sugestions?
i didnt know the alternator had a fuse??
its usually directly connected to the battery.......
first off.....what kinda car is it? what engine/ECU? what fuse exactly is blowing? where is it located and whats the size? also what else (electrical) did you install onto the car?
2000-2001 Integra, it would be the secondardy O2 sensor heater circuit...guess how I know
I found this out 3 years ago the hard way. For me it was the wires rubbing against the body, which caused a short.
Austin
I found this out 3 years ago the hard way. For me it was the wires rubbing against the body, which caused a short.Austin
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Austin »</TD></TR><TR><TD CLASS="quote">2000-2001 Integra, it would be the secondardy O2 sensor heater circuit...guess how I know
Austin</TD></TR></TABLE>
its a 2001 integra, although i converted to obd1 so im not running a secondary O2. the car is stock but i just threw a gsr swap and modified my ls harness. all the wires that i could see look good. car was running fine after the swap for about 500 miles
I found this out 3 years ago the hard way. For me it was the wires rubbing against the body, which caused a short.Austin</TD></TR></TABLE>
Swoops
Sep 3, 2022 01:44 PM
Coolero
Mar 4, 2010 10:21 AM
LOWLIFEHATCH
Apr 24, 2005 11:37 AM
