reuse rod bolts?
Old Mar 1, 2004 | 01:09 PM
kaj's Avatar
kaj
Default reuse rod bolts?
i have a b18c with less than 50k miles (if it matters). can i reuse the rod bolts? i will only be doing the rod on one piston (repair ). i want to be sure they aren't torque to yield or anything else crazy like that. i'm already planning on studding the head... do i need to get rod bolts too?
Old Mar 1, 2004 | 01:35 PM
non-VTEC's Avatar
Default Re: reuse rod bolts? (kaj)
just follow the correct torque spec in the helms manual and you will be fine.
no need to replace the rod bolts.........BUT since you are already down at the bottom end it probably wouldent hurt to replace them with some new ARP rod bolts.
its not that important but they could help in the long run if you plan to make some more power/rpm.
hope this helps.
Old Mar 1, 2004 | 01:43 PM
kaj's Avatar
kaj
Default Re: reuse rod bolts? (non-VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by non-VTEC &raquo;</TD></TR><TR><TD CLASS="quote">just follow the correct torque spec in the helms manual and you will be fine.
hope this helps.</TD></TR></TABLE>
yup. sure does.. i think i'll wait 'till i do aftermarket pistons/rods. thanks!
dpine
Engine Machining & Assembly
Mar 23, 2017 09:38 PM
rich7777
Mar 1, 2010 07:43 AM
12secB18acivic
Sep 25, 2002 01:42 AM
magicwand
May 26, 2002 08:36 PM
