Broken Header Bolt
Old Mar 1, 2004 | 08:15 AM
Canonm7's Avatar
Default Broken Header Bolt
Hey guys,
Don't know how it happened but I broke one of the bolts to bolt down my header. I was installing my DC Sports Headers and guess I overtighten. Any tips on how to get that sucker out?
Thanks.
Old Mar 1, 2004 | 09:17 AM
Filthy Focker!'s Avatar
Default Re: Broken Header Bolt (Canonm7)
Were your bolts all rusted out????
where did it break?
Is it flush with the surface?
Answer these questions and we will see..
Those are a b*tch to take out....
fs
Old Mar 1, 2004 | 10:10 AM
immalooser's Avatar
Default Re: Broken Header Bolt (filthy_shovel)
Do you mean one of the stud off your cylinder head?
If so i had that same problem when i installed my DC. Apparently they did not make their welds correctly so one of the bolts would not completely fit.
Pic:
If that's the case you have to drill into the broken stud, then use a reverse drill bit and drill the sucker out. It's a very intensive process b/c you have to drill perfectly straight otherwise you might end up drilling elsewhere causeing more problems.
Old Mar 1, 2004 | 04:46 PM
raceACCORDingly's Avatar
go to a muffler shop, my friend had a broken header bolt and they welded the head of another bolt to the tip of the broken bolt and then took it out.
Old Mar 1, 2004 | 05:35 PM
iam7head's Avatar
Default Re: (raceACCORDingly)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by raceACCORDingly &raquo;</TD></TR><TR><TD CLASS="quote">go to a muffler shop, my friend had a broken header bolt and they welded the head of another bolt to the tip of the broken bolt and then took it out.</TD></TR></TABLE>
that would work if the bolt broke out side of the block, hell, just dremel a slot and take it out with a long screw driver.
those craftsman drill out wouldnt do it tho'
Old Mar 1, 2004 | 07:30 PM
AcCO12D95's Avatar
I broke mine off also, putting back on my stock header. I broke the stud next to the alternator or starter not sure, but the damn thing is in the way..
I still have not fixed mine for about 4 months, since I need to remove all the crap in the way, to drill it out...
Someone wanna fix mine for me.... I've got the new stud from Honda
Old Mar 2, 2004 | 04:06 AM
Canonm7's Avatar
Default Re: Broken Header Bolt (AcCO12D95)
The one near the alternator is the same one that I broke. I bought a replacement one at honda for like $4. The only issue is geting the old one out. Unfortunetly there's no piece outside the head. I'm going to try go get you guys a picture.
Old Mar 2, 2004 | 04:26 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Canonm7 &raquo;</TD></TR><TR><TD CLASS="quote">The one near the alternator is the same one that I broke. I bought a replacement one at honda for like $4. The only issue is geting the old one out. Unfortunetly there's no piece outside the head. I'm going to try go get you guys a picture.</TD></TR></TABLE>
The reason your bolt broke is because it tempered itself and became brittle..
Ok, here's what you need to do:
1. Try to drill it a hole in it using a dremel or drill if you can...
2. Heat up the bolt a bit
3. grab some paraffin (stuff you cook with) and stick it on the broken stud - you are trying to work the paraffin inside the threads.
4. Grab and easy out and work it in the hole you drilled and turn clockwise, counter clock wise to work it out. If after 3 minutes or so this does not work, wait a while to let things cool down and repeat the steps....
fs
Just1nK4ng
11
Aug 10, 2018 02:41 AM
danteisme
Oct 14, 2006 10:36 AM
JohnQPublic
May 26, 2006 07:15 PM
SexyAzNMami
Apr 23, 2005 05:20 PM
EF_LSVtec
Oct 3, 2002 06:30 AM
