disc brake conversion
Old Mar 1, 2004 | 06:02 AM
DaKINE-Ek's Avatar
From: So Cal where old pople try to race you, U.S.A
Default disc brake conversion
i have a 96 civic hatch dx and was wonderin how would get disc breaks in the back. and how much would it cost me?
Old Mar 1, 2004 | 06:03 AM
snoochtodanooch's Avatar
Default Re: disc brake conversion (dakineboiracin)
head over to http://turbod16.com and go under the FAQ section, their is a whole write up on this subject.
Old Mar 1, 2004 | 06:07 AM
Takeoff's Avatar
Default Re: disc brake conversion (snoochtodanooch)
You can use 94-01 integra rear trailing arms w/ ebrake cables. It is pretty easy. Just unbolt the stock lower control arm and then bolt up the integra one. Attach all necessary cables and lines, blead the brake lines, and then get an alignment a.s.a.p.
Old Mar 1, 2004 | 06:08 AM
DaKINE-Ek's Avatar
will the 96-00 civic ex disc conversion by AEM fit?
Old Mar 1, 2004 | 07:23 AM
Marauder's Avatar
The AEM conversion is pricey....the plus side of it is that it uses brand new parts.
Using either 94-01 integra or 99-00 civic si rear disk parts works. You can usually find all the parts to do the conversion for between $200-350. I picked up a set of civic si rear suspension/disk brakes with ebrake cables for $200 which I sold to a friend. He just installed them with new pads and resurfaced the rotors.
Old Mar 1, 2004 | 07:45 AM
pdiggitydogg's Avatar
you can use rear arms from a del sol si or vtec as well as the arms from a 92-95 civic si or 4dr ex w/ rear disc
FGride
May 7, 2006 10:22 PM
90AccordVTEC
Apr 26, 2006 10:30 PM
turbob16a522
Jun 22, 2005 03:46 PM
gray89si
Aug 10, 2004 01:27 PM
