No spark/fuel no start
I've searched and seen that the most common things are Main relay or bad ECM. Is there anything else that may cause this? I know my wiring is spot on, so that's not even an issue. I've checked the ECM and I don't think that is the issue either, and the Main seems to be funcional- when put into another car. Anyone have any thoughts?
car- 98 LS with GSR harness, OBDI motor, no SRS installed
could taking out the srs cause the issue? I noticed that the srs and fuel pump were on the same fuse.
Pulling the srs shouldn't involve it. i didn't think the the srs and fuel are on the same fuse. I thought the srs fuse had a yellow rubber on it and the fuel was right beside it. (might be wrong) My guess would be the main relay though.
I'm going to get a new Main, just found out that one of my moron friend's doesn't know how to hook up a battery charger and put the neg on pos. to charge... which could have blown the main
I don't know... I can always take a relay out of the vic, but I bought a new main relay today... I'm going to get another ECM and see if that is the issue... I hope she starts tonight, I can't take much more of this ****!
Jcgbeasttube
Honda Civic (2006 - 2015)
Mar 19, 2018 10:07 PM
