LS crank, b16 block, and head.
Old Feb 29, 2004 | 10:25 PM
vtec95sol's Avatar
Default LS crank, b16 block, and head.
I have a few questions.
1: Can you run an LS crank, with LS length rods in a b16 (i know it will work in a b18)
2: If i do that, and have the block sleeved to 85 mm's what would my displacement be?
3: With the stroke how it would be, would Toda B's have to much lift, or cause any problems?
any and all thoughts are welcomed. Thank you
Old Mar 1, 2004 | 01:42 AM
slammed_93_hatch's Avatar
Default Re: LS crank, b16 block, and head. (vtec95sol)
um not too sure on this but this is what i think
deck height on the b16a is smaller then on the b18's. so im thinking with out custom rods or something you will be putting the piston out of the sleeve.
again this is just my speculation not positive can some one either back me up or prove me wrong
Old Mar 1, 2004 | 07:41 AM
Rollo Lawson's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec95sol &raquo;</TD></TR><TR><TD CLASS="quote">I have a few questions.
any and all thoughts are welcomed. Thank you</TD></TR></TABLE>
actually, i have a magazine that did just that. they installed an 89mm crank, custom rod (which allowed an oem sized piston to be used) & forged oem sized pistons (81.5mm, increasing displacement to 1859cc). the b16 block had to be notched to accomodate the additional stroke. i don't know what the r/s ratio (1.44 ish?) would be, but, i can tell you that the b16 was transformed into a small monster. in stock configuration, the b16 made 148whp & 107wtq with stock bottom end and a few bolt on's. when the 89mm crank was installed with custom rod, pistons, crane stg 2 cams, ported p30 intake manifold, upgraded valves, aem cam gears, edelbrock header, mild head porting, 68mm t/b, r/c injectors (11.5/1 c.r.) resulted in 203whp & 150.5wtq . i don't know if i would bother with this type of set up (because hard driving could possibly pulverize the bearings and internals due to a poor r/s ratio) even though it wouldn't be that expensive to build. this would be the ultimate sleeper motor. the block would read b16a, but, the dyno would be screaming out b20 vtec numbers. good luck.
Old Mar 1, 2004 | 08:45 AM
vtec95sol's Avatar
thats kinda what i was going for was having the block and everything still look stock. but i think it seems safer to go with a b18c block.
Old Mar 1, 2004 | 09:24 AM
Default Re: (vtec95sol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec95sol &raquo;</TD></TR><TR><TD CLASS="quote">thats kinda what i was going for was having the block and everything still look stock. but i think it seems safer to go with a b18c block.</TD></TR></TABLE>
yep. i do have a question though. are you going to build the b18c bottom end? and if so, are you going to use forged internals or oem parts? and, do you plan on drag racing or circuit & auto-x racing? because if you have a bit of change there are other options.......ls/vtec or b17/b20 ...just a thought.
Old Mar 1, 2004 | 10:35 AM
vtec95sol's Avatar
i dont want the complications of putting a VTEC head on a non Vtec motor. but i plan on putting an LS crank, and LS forged rods into a b18c's bottom end. with custom pistons
TECH43 RACING INC.'s Avatar
yes you can, with my piston set shown below.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec95sol &raquo;</TD></TR><TR><TD CLASS="quote">2: If i do that, and have the block sleeved to 85 mm's what would my displacement be?
displacement will be 2020 cc's. my pistons are 85mm so you are in luck.
no problems at all. these pistons have reliefs that will clear cams up to 13.00 mm of lift.
kit comes complete with rings-wrist pins-locks-buttons
compression ratio is 11.5 to 1 with a b16a head unmilled and stock gasket.
dedicated valve reliefs and lots of internal milling to reduce weight. piston weighs in at a mere 255 grams! most off the shelf 85mm pistons with this dome weigh around 315g.
custom .708 lightweight tool steel wrist pin. rod must be rebushed to this from .826
custom machined buttons to support oil ring. this is how i can fit all that crank and rod in a b16a block. yes, you still retain the ls 1.54 rod ratio.
parts needed.
b16a block sleeved to 85mm. in stock.
TECH43 b16a 2.0 piston kit. in stock.
ls crank in stock.
ls rods ( rebushed to .708) in stock.
we've got these engines making appx. 230 whp on pump gas with honda intake manifolds and ecu's.
the 2.0 b16a you saw in the magazine won't live long, sleeves start to barrel out with that much stroke with such a crappy rod ratio. and 203 whp? lol...please. theres b16a's on pump gas 1.6l making that. those guys are lost. i think this kit makes a pretty mean b16a sleeper engine. complete shortblocks or piston kits available. steve@tech43.com
Modified by TECH43 RACING INC. at 11:55 AM 3/1/2004
Modified by TECH43 RACING INC. at 11:32 AM 3/24/2004
Old Mar 1, 2004 | 11:40 AM
3.504's Avatar
Default Re: LS crank, b16 block, and head. (TECH43 RACING INC.)
you could also run a gsr 3.433 crank w/ the b16 rods and a .137 raised wrist pin piston set to give you 1.54 r/s ratio then run the size bore you want... you'll prolly need to notch the block to clear the crank but the pistons wont ride over the deck w/ this setup.....
as for the 3.504 w/ 5.394 rods.... you're gonna need pistons that have the wrist pin raised .333"..... which means the wrist pin is gonna be far into the oil ring... the highest wrist pin i've ever seen was raised .250..... so i dont really see the 5.394 rods working and w/o those... you're r/s ratio would be crappy on the 3.504 crank (ls crank).... i'd just go w/ a gsr crank (3.433) to get the stroke you'll need.... and as for displacement w/ a 3.433 on 85mm sleeves...120.53 cid which is just under 2.1 liter
Old Mar 1, 2004 | 12:54 PM
R6Boy69's Avatar
those pistons sure are pretty...
Old Mar 1, 2004 | 01:10 PM
Default Re: LS crank, b16 block, and head. (3.504)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 3.504 &raquo;</TD></TR><TR><TD CLASS="quote">as for the 3.504 w/ 5.394 rods.... you're gonna need pistons that have the wrist pin raised .333"..... which means the wrist pin is gonna be far into the oil ring... the highest wrist pin i've ever seen was raised .250..... so i dont really see the 5.394 rods working and w/o those... you're r/s ratio would be crappy on the 3.504 crank (ls crank)</TD></TR></TABLE>
hmm...apparently you completely missed my post.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TECH43 RACING INC. &raquo;</TD></TR><TR><TD CLASS="quote">
Old Mar 1, 2004 | 02:01 PM
Katman's Avatar
nice lookin **** there Mr. Wheaton
Old Mar 1, 2004 | 02:37 PM
_unknown_'s Avatar
hmmm pistons pics...
right click'd and saved....
Old Mar 24, 2004 | 05:07 PM
TOM J's Avatar
Old Schooler
Nice pistons Tech43
Old Mar 24, 2004 | 11:07 PM
Default Re: LS crank, b16 block, and head. (TOM J)
thank you mr. tom.
Old Mar 25, 2004 | 12:15 AM
importboi22's Avatar
now only if that piston was made in 81mm
Old Mar 25, 2004 | 06:15 AM
owen_the_soyboy's Avatar
Default Re: LS crank, b16 block, and head. (importboi22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by importboi22 &raquo;</TD></TR><TR><TD CLASS="quote">now only if that piston was made in 81mm</TD></TR></TABLE>
Old Mar 25, 2004 | 07:16 AM
_unknown_'s Avatar
Default Re: LS crank, b16 block, and head. (owen_the_soyboy)
Steve... looks like you should put in another order for 81.5mm pistons!!!
Old Mar 25, 2004 | 07:59 AM
pro1342's Avatar
Super nice pistons.....price?
Modified by pro1342 at 11:22 AM 3/25/2004
Old Mar 25, 2004 | 11:11 AM
Default Re: (pro1342)
81.25 and 81.5 mm pistons should be avialble!! 1.8 b16!!!
Old Mar 25, 2004 | 11:13 AM
Default Re: (importboi22)
also could ya make pistons work with a GSR crank, for us of those who want to use the beefier GSR rods?
Old Mar 25, 2004 | 11:19 AM
i can make 81.50 and 82.00 mm pistons for those who want to avoid sleeves. i can also set them up for gsr cranks. im for prices.
Old Mar 25, 2004 | 11:39 AM
TOM J's Avatar
Old Schooler
Default Re: (TECH43 RACING INC.)
Tech43 I have a set of 83mm turbo strokers b16 block and Ls rod Ls crank if you need them.
Old Mar 25, 2004 | 11:40 AM
pm'd
Old Mar 25, 2004 | 12:24 PM
_unknown_'s Avatar
These pistons are the most innovative I have seen to date for B-series motors.
Old Mar 25, 2004 | 02:31 PM
Default Re: (garth)
i noticed on the buttons that support the oil ring i was curious if this setup would last on a daily driven car?
