Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Yoko A032R, auto-X and DRAG?
Old Oct 15, 2001 | 06:47 AM
austrian type-R's Avatar
Default Yoko A032R, auto-X and DRAG?
Is the Yokohama A032R only good for autocross, or is it a nice DRAG rubber too?
Old Oct 15, 2001 | 06:57 AM
BryanSprinkel's Avatar
Default Re: Yoko A032R, auto-X and DRAG? (austrian ITR)
i have used these tires for all 3, autoX, drag, and track. I say not so good for Drag, stiff side walls, and drag racing dont mix very well. I love these tires for the track and AutoX though.
Bryan
Old Oct 15, 2001 | 07:10 AM
Default Re: Yoko A032R, auto-X and DRAG? (VAtypeR00)
whats about the Yoko A038R? Is it better than the A032R?
Whats about with the A006? This rubber has a soft sidewall for DRAGing
[Modified by austrian ITR, 8:12 AM 10/15/2001]
Old Oct 15, 2001 | 07:18 AM
I wouldn’t know. It’s just been my experience that a tire with a stiff side wall, will not do very well in drag racing. When comparing the Re010 to the AO32R, I ran a 9.6 in the 1/8 with the RE010s, and a 9.5 with the AO32R but a lot of things could have had an affect on that. That was bone stock with just the tires.
Bryan
Old Oct 15, 2001 | 07:20 AM
MaddMatt's Avatar
I've noticed that the typical autocross/road race tires obviously have great lateral grip, but aren't much better than street tires for launching grip. My 60 ft times at the Petersburg Prosolo from the last 2 years (last year on V700s, this year on AVS intermediates) were about the same.
Never heard of the AO38R.
Old Oct 15, 2001 | 07:37 AM
krshultz's Avatar
Default Re: Yoko A032R, auto-X and DRAG? (MaddMatt)
I seem to remember GRM testing some tire from Nitto that was a streetable drag tire. I'm sure the name had Extreme something-or-other in it. Anyway, they took it around some turns and said it was surprisingly competent.
So those [Nitto drag radials] might be the way to go. No idea on their longevity though. And bear in mind - a tire that is decent at all of these things won't be great at any of them.
Old Oct 15, 2001 | 08:31 AM
getfast's Avatar
Default Re: Yoko A032R, auto-X and DRAG? (krshultz)
That would be the Nitto NT555R Extreme Performance High Performance Racing Style Street Racing Tire Type R, or whatever it's called. I heard it was a street 555 (i.e. softer street sidewall) with a stickier compound rubber, and that it was indeed surprisingly competent at all three activities when the pressures were adjusted correctly for each. I have no first-hand knowledge of this, though.
HTH,
RacerJon
Old Oct 15, 2001 | 08:54 AM
Default Re: Yoko A032R, auto-X and DRAG? (TAFKARJ)
yes these tires are called Nitto 555r's Drag radial. I have had these as well 205-45-15 once again the small side wall. They did improve my 60' times by about .1 so maybe they are worth it. If you are going to drag, get a drag tire, and a race tire for all other track and autoX's. I burnt up a set of AO32Rs drag racing, and never got to use them for there real purpose
Bryan
[Modified by VAtypeR00, 12:56 PM 10/15/2001]
Old Oct 16, 2001 | 08:29 AM
AllMotorMadness's Avatar
ao32r's work good for drag also....................
CaliforniaDad
Jan 3, 2014 01:28 PM
CRXherbie91
Feb 18, 2013 05:07 PM
99JDMHATCH
Feb 17, 2010 10:10 AM
RZbltCRX
Jan 24, 2006 02:25 PM
BlueG3Teg
Dec 31, 2001 08:01 AM
