Cam gears: Which ones?
Old Oct 15, 2001 | 06:22 AM
teg92's Avatar
Default Cam gears: Which ones?
I'd like to know, out of the three which is better quality and has a better design. AEM, WeaponR and Hayame? I know everybody is gonna say get spoons or todas or whatever but please just give me your opinion out of the 3. Thanks!
AEM
WeaponR
Hayame
Thanks
[Modified by teg92, 3:48 PM 10/15/2001]
Old Oct 15, 2001 | 07:16 AM
GTEater's Avatar
Default Re: Cam gears: Which ones? (teg92)
why not the skunk2.......i think theres a groupbuy on them right now......if you look at them, the skunks have less surface area than the others, so they are probably lighter, plus they have 6 bolts
Old Oct 15, 2001 | 08:03 AM
teg92's Avatar
Default Re: Cam gears: Which ones? (GTEater)
Well the Hayame has 6 bolts, the weaponR looks a bit like the spoon ones, and AEM well has just the reputation...
Old Oct 15, 2001 | 08:05 AM
owen_the_soyboy's Avatar
skunk2, toda or spoon.
Old Oct 15, 2001 | 08:10 AM
teg92's Avatar
Default Re: Cam gears: Which ones? (owen_the_soyboy)
Owenthesoyboy: thanks for reading my post
Old Oct 15, 2001 | 08:29 AM
LS-T's Avatar
New User
try skunk2.....they are cheaper than AEM and prolly work better
Old Oct 15, 2001 | 08:57 AM
teg92's Avatar
Default Re: Cam gears: Which ones? (Armani692)
Ok maybe I should explain why I am choosing the three. I'm buying them used, I've seen them all and they're all in perfect shape... I can get the AEM's for $120, Hayame $155 and weaponR for $140...
Old Oct 15, 2001 | 11:52 AM
Dirty GS-R's Avatar
New User
Out of the three, I would take the Hayame but only because it's 6 bolts. I hear a lot of negative things about the aem cam gears so I would stay away from those.
dplatt's Avatar
I had a set of AEMs on my car for quite a long time. Never had any problems with slipping or anything and I adjusted them probably four times in one year. So from your choices, I would get the AEMs. And when you tighten the bolts, tighten them right till the allen wrench starts to bend.
If you ever do decide to upgrade cam gears to like Toda, JUN, or Spoon, you may want to consider the new JGs as well. They are now made out of 7075 aluminum and have 4 bolts. Seem like very good quality gears.
Best of luck.
Old Oct 15, 2001 | 11:58 AM
EVOCELICA's Avatar
New User
Default Re: Cam gears: Which ones? (dplatt)
For all that are interested I make and sell cam gears please click below for more info. I can let a single pair go for $165 shipped to your door. If bulk is purchased I can give a way better price.
https://honda-tech.com/zerothread?id=78508
Louie_EM1
May 10, 2004 01:01 PM
respectblades
Sep 7, 2003 12:13 PM
Boostless97Lude
Feb 14, 2003 03:39 PM
JeffNA
Feb 27, 2002 08:05 AM
B2FiNiTY
Dec 7, 2001 06:50 PM
