Building an LS head, Need some advice
Old Feb 29, 2004 | 07:59 PM
Thrillhouse's Avatar
Default Building an LS head, Need some advice
My plans are LS head, with crower 403's titanium retainers, and dual valve springs. I need to replace the cam seals, and clean everything up real nice (bought the stuff used). I am going to get a hondata IM gasket, and a new head gasket and timing belt. Does anyone have any good tips for me? This will be my first build.
I bought the head so I can work on it over time because I cant afford that much down time, and I wanna learn it with out rushing. Basically what I need to know is, is there anything else I need to replace while im in there? And what should my lash settings be with the crowers?
B18B's dont have cam bearings? I noticed there were no bearings for the cams.
Old Feb 29, 2004 | 08:19 PM
not so civic's Avatar
From: gravity rides everything...everything will fall, se GA/ne FL
Default Re: Building an LS head, Need some advice (Thrillhouse)
assembly/break in lube everything up there and set the lash to stock spec. if your doing the valve train, maybe try and at least put in some tapered intake stainless valves (thinner stem in the port area) for more airflow.
don't use the stock ls intake manifold. try and use a skunk, itr or b16 modded to fit the head. if you are interested in a '00 si intake manifold already made to fit a ls head then pm me for details and pics.
Old Feb 29, 2004 | 09:22 PM
Default Re: Building an LS head, Need some advice (not so civic)
Whats wrong with the stock LS IM?
Old Feb 29, 2004 | 09:33 PM
marieT1GRL's Avatar
new valve seals, guides, valves..... the stock LS mainfold is good for stock LS motors, if you bump up the compression, say 11.8-12.5:1 then go with SKUNK2 mani... good luck on your build up...
Old Mar 1, 2004 | 09:23 AM
Default Re: Building an LS head, Need some advice (ThatOneGirl)
Thx for the info. Anything else?
Old Mar 1, 2004 | 10:24 PM
What kinda seals and O rings do I need to get, is there a whole kit I can buy to get all of them? Do i need two cam seals? or does the distributor side have a seal on it?
Old Mar 2, 2004 | 07:32 AM
eghonda's Avatar
call up honda they have a upper gasket/seal kit with everything u should need
Old Mar 2, 2004 | 07:52 AM
Default Re: Building an LS head, Need some advice (eghonda)
RAD thx for the info!
Old Mar 2, 2004 | 08:14 AM
acydphryck's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Thrillhouse &raquo;</TD></TR><TR><TD CLASS="quote">Whats wrong with the stock LS IM?</TD></TR></TABLE>
stock LS IM doesn't flow as well as the other ones mentioned...i.e. Skunk2...etc.,
Old Mar 2, 2004 | 08:48 PM
Default Re: Building an LS head, Need some advice (acydphryck)
What about head studs? isnt it true that once the old ones have been torqued down they strecth? So wont I have to get new head studs?
Old Mar 2, 2004 | 09:12 PM
Do I need two cam seals?
Old Mar 2, 2004 | 10:03 PM
LsPoweredEF's Avatar
yes that is true about the head studs, get ARP head studs jsu as a suggestion u may wanna get a thiner head gasket to bump comressiona little nothing wrong witha little pep, also before u put the head back on u have to have it resurefished, so have it milled .020-.030 wouldnt hurt
Old Mar 2, 2004 | 10:29 PM
Default Re: Building an LS head, Need some advice (LsPoweredEF)
I HAVE TO have it resurfaced?
Old Mar 3, 2004 | 02:35 AM
chris_m's Avatar
* B A N N E D *
I recommed speaking to dh-racing.com. he does alot of work on ls heads.
Old Mar 3, 2004 | 07:39 AM
Default Re: Building an LS head, Need some advice (alld16a)
ya its a good idea to resurface the head it makes sure its not worped
i also recamind maybe milling it a little bit it will raise ur compres sion
Old Mar 3, 2004 | 08:24 AM
Im not sure how much money im gunna have after buying everything, so im not sure if I will have the cash to get it milled. If I check the deck for warpage myself and there is none then I should be good right?
Old Mar 3, 2004 | 12:16 PM
ya u could check ur self they make a tool to do it, and theres a seaquince but if its good than dont worry about it
Old Mar 3, 2004 | 12:55 PM
Rob Dizzle's Avatar
are there any other choices to for other ls intake manifolds?
Old Mar 3, 2004 | 07:19 PM
Default Re: Building an LS head, Need some advice (Bob-DC2)
All you need to check for deck warpage is a straight edge and feeler gauges, and the sequence is straight accross the bores in 5 spots, angled from one corner to the other in 5 spots and angled the other way in 5 spots. If no feeler gauges fit then you should be golden.
Old Mar 4, 2004 | 09:52 AM
correct
Old Mar 6, 2004 | 11:35 AM
HOLY ****! I went to get my straight edge and well some ****** dropped it or some **** and now its not straight. SO, I went to home depot, pep boys, kragen, lowes and not a god damn one of them sells a true straight edge. They just sell rulers or t squares and **** like that. Does anyone know where to get a REAL straight edge besides the $300 snap on one?
Old Mar 6, 2004 | 12:14 PM
DonF's Avatar
Just get the head trued (surfaced) and be done with it.
Old Mar 7, 2004 | 12:47 AM
Default Re: Building an LS head, Need some advice (DonF)
thats the way i would go have someone mill it for ull notice a nice diff. from it
it wouldnt hurt to have it done
Old Mar 7, 2004 | 08:41 AM
K, I pulled apart the head its now down to the bare head. What should I use to clean the carbon out of the Exhaust ports and the valves?
Old Mar 7, 2004 | 11:59 AM
arw321's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Thrillhouse &raquo;</TD></TR><TR><TD CLASS="quote">K, I pulled apart the head its now down to the bare head. What should I use to clean the carbon out of the Exhaust ports and the valves?</TD></TR></TABLE>
Try brake cleaner or carb cleaner.
If you are having them head re-surfaced just have your machine shop hot tank it.
