Please help: Bad smell: the car, the clutch, or me?
Always about 3-5 minutes after I start my car and take off, I get a really nasty smell. Now the only way to describe the smell is that it smells like crap, ****, diarehha. The thing is, I smell the smell exactly when I really, really, feel the heat kick in. Since it's cold, I always have the heat on, and usually on setting #2. So when I feel the heat, I get the smell. Usually the amount of heat at this point is too much, I get too hot, so I lower the heat. After the smell fades aways, I never get it again until the next time I drive the car and that exact point where I once again feel the heat and get the smell.
Now I've been driving manual for about 4.5 months now, but I feel really confident about my driving-shifting. I don't see how I could be burning the clutch only once each time when beginning to drive every time I drive, it just doesn't make sense. And I don't get the smell anymore after the initial time.
if you get condensation in your heating system and dont use it for a while it can turn to mold. leave you heater and car on for about 15 minutes and it should clear it out.
Screw you guys, I'm... going... home.
I think either something died in your ventilation system, or you are driving by the same sewerage treatment plant every day. Commuters on I-40 in Raleigh NC will know what I mean!
hey i had 9.... i say again 9 mouse nest in my CRX when i got it...... afew in the dash...... 2 in the heater ducts...... 1 over head in the head liner and several in the rear...... pull off your center vents.....just pull gently and they should come out..... another thing .....if you have A/C then they love to build next to the A/C core.... hey you might have a dead mouse in there.... the moisture from sitting overnight sort of refreshin's it a bit.... takes a few min to dry out!!! hey you never know.... i had 2 alive in mine for a week....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by warchild69 »</TD></TR><TR><TD CLASS="quote">hey i had 9.... i say again 9 mouse nest in my CRX when i got it...... afew in the dash...... 2 in the heater ducts...... 1 over head in the head liner and several in the rear...... pull off your center vents.....just pull gently and they should come out..... another thing .....if you have A/C then they love to build next to the A/C core.... hey you might have a dead mouse in there.... the moisture from sitting overnight sort of refreshin's it a bit.... takes a few min to dry out!!! hey you never know.... i had 2 alive in mine for a week....</TD></TR></TABLE>
The live ones would be kinda gross.
No, there's definately no animals in there. Today was a beautiful warm day, so I drove without heat, and I think I did catch a hint of the smell.
I really don't think it could be my clutch. I'm pretty quick getting off of it, and I don't see how it could be burning so quickly.
From: I told you to wait in the truck in Texas, United States
Two things it could be:
1.-- heater core leaking..--
check your coolant level in the radiator
2. ---A/C condensation drain line clogged---
evaporator housing could be full of stagnant water..
I totally forgot to check up on this thread.
But here's an update after a month:
I still get the smell associated with heat, but it smells sometimes even without the heat. I do get the smell when I really push the car, as at WOT.
And yes, it does smell sort of like rotten egss, and also sulfur, definately sulfur.
Well if you don't have a zoo in the vents then a sulfur smell would/can come from the battery.make sure it isn't leaking down into the tray. take the battery out and check for any signs of corrosion?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nonsense »</TD></TR><TR><TD CLASS="quote">rotten egg or sulfer smell is Cat converter</TD></TR></TABLE>
yep, also listen for any ratteling like a heatshield is loose.
BIGthings
13
Feb 19, 2006 09:15 PM
d16y8EL
15
Apr 26, 2005 02:12 PM
Infamous_Imports
Feb 19, 2004 06:21 PM
Check out the air cleaner for the vents or maybe you have water getting into your car somewhere when it rains
