D16z6 pistons and rods d16a6 crank
Old Feb 29, 2004 | 05:35 PM
turbo420's Avatar
Default D16z6 pistons and rods d16a6 crank
can i use d16z6 pistons and rods, on my d16a6 crank and block? what bearings should i use?
Old Feb 29, 2004 | 05:42 PM
onePOINTsix's Avatar
Default Re: D16z6 pistons and rods d16a6 crank (turbo420)
yes, use the bearing specified by the crank code or use the bearing kit from Camp1320
Old Feb 29, 2004 | 07:29 PM
boostn420's Avatar
If you do that its gonna be really low compression your better of with either a6 pistons or a 92 up head.
Old Feb 29, 2004 | 08:41 PM
turbo420's Avatar
Default Re: D16z6 pistons and rods d16a6 crank (boostn420)
well i am turbo just want to turn up the boost, and dont have alot of money right now.. what do you think what head gasket should i use?
Old Feb 29, 2004 | 09:30 PM
88civichbz6's Avatar
go with ls pistons i believe they will work and will be stronger i forget what year you have to get them from i think its the early 90's
Old Feb 29, 2004 | 09:40 PM
civicsitek GanGsTa's Avatar
Default Re: D16z6 pistons and rods d16a6 crank (88civichbz6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88civichbz6 &raquo;</TD></TR><TR><TD CLASS="quote">go with ls pistons i believe they will work and will be stronger i forget what year you have to get them from i think its the early 90's</TD></TR></TABLE>
LS rods work, ls pistons do not
Bay Area Baller
11
Oct 16, 2006 04:35 AM
88crx-si
Jun 12, 2006 04:49 PM
vtecspeed1320
Jan 24, 2006 06:04 PM
Simple SOHC
Jan 20, 2004 07:09 PM
