Problems with HIGH Water Temp
Old Feb 29, 2004 | 05:31 PM
MugenB16A2's Avatar
Default Problems with HIGH Water Temp
OK, tonight when I got off work, my Girlfriend tells me that her LS/VTEC Motor is overheating...
When I checked the Water Temp gauge on the CTR Cluster... I noticed it slowly rise...
After driving it around it starts to decrease, but once the car returns to idle, the Temp Raises to an awkardly High Temp...
What could be wrong????
It worked fine from the start and the Motor has about 3000 miles on it.
Old Feb 29, 2004 | 05:43 PM
onePOINTsix's Avatar
Default Re: Problems with HIGH Water Temp (MugenB16A2)
blown headgasket, sorry had the same thing happen to me on my D15
Old Feb 29, 2004 | 05:47 PM
MugenB16A2's Avatar
Default Re: Problems with HIGH Water Temp (Sideout)
Seriously???? What could have caused this???
Too Much compression???
Not doubting you, but would anyone else have any other conclusions to what it might be???
Old Feb 29, 2004 | 08:25 PM
boostn420's Avatar
Yeah, blown headgasket.
Old Mar 1, 2004 | 08:43 AM
King-Kong's Avatar
look at your exhaust and smell it, if there is white smoke coming from the tail pipe then its a head gasket, if there is no sign maybe your coolant is low, i doubt that you have an air lock unless you did a rad flush, and change the thermostat, work from simple to the more difficult.
PINKS
Sep 2, 2006 04:19 AM
PINKS
Aug 31, 2006 04:57 PM
PINKS
Aug 24, 2006 09:49 AM
PINKS
30
Aug 23, 2006 08:13 PM
MugenB16A2
Feb 29, 2004 10:49 PM
