have you heard of 81.5m p73 pistons?
Old Feb 29, 2004 | 05:07 PM
jeremy.'s Avatar
Default have you heard of 81.5m p73 pistons?
i just found out after replacing the rings on my pistons that i was overbored...i always thought oem pistons only 81.25 max......and p73's can go up to 82 oem. i have geniune p73's jdm itr pistons, it's a trip. i've asked a couple people and they have heard of them, but why is it so uncommon? thanks
Old Feb 29, 2004 | 05:28 PM
specie's Avatar
Default Re: have you heard of 81.5m p73 pistons? (ek_jeremy)
oem b-series goes to 81.25mm. I believe people are talking about aftermarket replicas.
Old Mar 7, 2004 | 12:10 PM
jeremy.'s Avatar
Default Re: have you heard of 81.5m p73 pistons? (specie)
no they don't.....TECH43 RACING INC. has the part numbers
Old Mar 7, 2004 | 07:01 PM
fox297's Avatar
A few months back, this guy told me he could get 81.5mm OE but only for the USDM pistons. There's no 81.5mm for any JDM pistons.
Old Mar 7, 2004 | 07:09 PM
george jetson's Avatar
81.5 p73 pistons are oem replicas, the use honda part #'s. RS sells them also
Old Mar 8, 2004 | 05:04 AM
Lip's Avatar
Lip
Default Re: (george jetson)
i could be wrong...but from what i remember OE pistons come in stock bore, .25 and .5 over bore. Check with your local honda dealer or call up A&H at http://www.AHmotor.com
Old Mar 8, 2004 | 11:46 AM
Disco Monkey's Avatar
Default Re: (Lip)
i remember a post by mike k from a long time ago. i believe he posted up about there being an oem 81.50 mm usdm p73 piston
edit
this is the only post i could find from mike k about it
https://honda-tech.com/zerothread?id=692892
but this is not the one i was thinking about...maybe it was someone else that posted about it.
Old Mar 8, 2004 | 12:25 PM
thad
Guest
Posts: n/a
now this has got me curious, are there truly any oem 81.5 pistons or are there people making replicas with similar part #s and if so how reliable are they? anybody got some hard facts,
T.I.A.
Old Mar 8, 2004 | 03:06 PM
Mike K's Avatar
Default Re: (thad)
these pistons in question, the 81.5mm and 82.0mm are manufactured by the same company who makes OEM honda pistons, but they are NOT available from dealerships, just race shops. you can find out who with a search, i don't know.
but these would be a real good candidate for LS/VTEC with factory reliability and more displacement. the 82.0mm would make for a small 1.9 liter, and easily 140tq on the dyno, tuned properly.
Old Mar 8, 2004 | 04:05 PM
riceball777's Avatar
oem is only 81mm and 81.25mm
the 81.5 and 82mm itr pistons are oem copies
RS machines sell them
and 82mm would be great for anyone doing a lsvtec with stock sleeves mak ing it a 1.9
Old Mar 8, 2004 | 06:55 PM
lazyguy's Avatar
Default Re: (Mike K)
i have a set of these ill be running in my gsr build up which is close to completion ill let u guys know how it comes out when i finish it
Old Oct 12, 2004 | 11:13 PM
ceLtic's Avatar
N/A wh0re!
Default Re: (lazyguy)
sorry to bump an old thread, but since i have OEM P73 pistons
box number[s]are 13010-p73-j00 these would be in standard bore at 81mm right?
Old Oct 13, 2004 | 05:41 AM
irev210's Avatar
Default Re: (ceLtic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ceLtic &raquo;</TD></TR><TR><TD CLASS="quote">sorry to bump an old thread, but since i have OEM P73 pistons
box number[s]are 13010-p73-j00 these would be in standard bore at 81mm right? </TD></TR></TABLE>
correct
13020-p73-j00 are oversized
13010-p73-j00 are std bore
Old Oct 13, 2004 | 08:26 AM
sittin on GOLD's Avatar
Default Re: have you heard of 81.5m p73 pistons? (ekay_jeremy)
camp1320.com has 81.5mm pistons in stock
Old Oct 13, 2004 | 08:59 AM
MikeySpec's Avatar
Default Re: have you heard of 81.5m p73 pistons? (advertise)
Isnt it Topline who make the copies?
Old Oct 13, 2004 | 12:11 PM
irev210's Avatar
Default Re: have you heard of 81.5m p73 pistons? (MikeySpec)
There is topline and there is nippon
I give to people that try to sell them as OEM honda
Cheap alternative pistons... but still not OEM honda
Old Oct 13, 2004 | 02:41 PM
pane93civhb's Avatar
Default Re: have you heard of 81.5m p73 pistons? (irev210)
does anyone no how much these pistons run.. becuz im doing an ls/vtec and bigger bore might do me some good.
Old Oct 21, 2004 | 10:34 PM
Slow_Em1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by specie &raquo;</TD></TR><TR><TD CLASS="quote">oem b-series goes to 81.25mm. I believe people are talking about aftermarket replicas. </TD></TR></TABLE>haha replicas?...rota's new line of conduct.
89hybrid
Nov 18, 2014 03:02 PM
97accordbuildlx
Jan 19, 2013 07:55 AM
hmongyaj87
May 31, 2008 03:13 AM
kidwit93delsol
Nov 7, 2007 12:23 PM
