Steering Rack Problems
Old Feb 29, 2004 | 04:43 PM
sloweh3's Avatar
Default Steering Rack Problems
Ok, I called Advanced, CarQuest, and Pepboys looking for a new steering rack. Every time I tell them no power steering, they tell me that in their computer, every 88-91 civic in there says power steering. This is starting to **** me off. I'm running a DOHC ZC in my DX, but I still have the stock DX rack. Does anyone know why their computers are coming up power steering? Thanks.
Old Feb 29, 2004 | 05:21 PM
silverCRXTC's Avatar
Default Re: Steering Rack Problems (H82BLGL)
probally because all they sell is the power steering replacement, you might have to goto a junkyard to get a new rack, whats wrong wtih your rack?
Old Mar 1, 2004 | 08:07 AM
sloweh3's Avatar
Default Re: Steering Rack Problems (silverCRXTC)
My rack has a lot of play in it. You can take the steering wheel, and turn it 1/4 of a turn left and right and hear "clunk" every time the rack hits the support. Could the nut on the steering column come loose and make it do this, or do I need a new rack?
Old Mar 1, 2004 | 08:18 AM
AgentJam's Avatar
how are your tie rod ends? 1/4 turn each way is a lot though but check ball joints first as well.
Vince
Old Mar 1, 2004 | 08:39 AM
sloweh3's Avatar
Default Re: Steering Rack Problems (AgentJam)
The ends are fine, and ball joints are fine as well. I just had both ends and both inners replaced in the past 6 months. The actual rack is what is banging. Could this be from the nut on the steering column coming loose?
Old Mar 1, 2004 | 08:45 AM
AgentJam's Avatar
Is the nut holding your steering column loose? It's pretty easy to check just right under the carpting in the car. How about the bolts holding the rack to the frame. Have you checked them? Torqued to spec?
Vince
Old Mar 1, 2004 | 09:02 AM
Filthy Focker!'s Avatar
if you rack is loose, you can adjust it... underneath is a big nut. In there is a spring and plastic piece that puts pressure on the shaft that rides the pinion... Simply remove that, put another spacer and retight.... Should be good for a while....
fs
Old Mar 1, 2004 | 09:29 AM
Crxer's Avatar
Try checking the two bolts that hold the steering rack up, it can also cause the steering wheel to feel loose. If you look under the car they will be on the drivers side where the rack starts going up to the wheel, its the only two bolts in the area you cant miss them.
Old Mar 1, 2004 | 09:39 AM
Default Re: Steering Rack Problems (Crxer)
and while your at it i would get some es bushing for it and be done with it!
Old Mar 1, 2004 | 09:58 AM
AgentJam's Avatar
I'm doing the ES steering rack bushings tonight...hard to do? I've got he Big 1.5" radius bushing that goes under the U clamp on passneger side (correct?). And 4 smaller bushings that i guess get stacked under those 2 bolts holding the drivers side as described above?
Correct me if i'm wrong...
Vince
Old Mar 1, 2004 | 11:23 AM
sloweh3's Avatar
Default Re: Steering Rack Problems (filthy_shovel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by filthy_shovel &raquo;</TD></TR><TR><TD CLASS="quote">if you rack is loose, you can adjust it... underneath is a big nut. In there is a spring and plastic piece that puts pressure on the shaft that rides the pinion... Simply remove that, put another spacer and retight.... Should be good for a while....
fs</TD></TR></TABLE>
Is the big nut under the steering column in the car, or under the car, by the rack itself?
Old Mar 2, 2004 | 04:38 AM
On a manual steering rack, the nut should be underneath or next to the pinion... Where your steering column bolts to the rack itself...
Get under the car and ask someone to turn the steering wheel, you will see the shaft, a steering knuckle (looks like a u-joint) then the pinion... remove the nut with a pipe wrench or something...
What happens on manual rack is the following:
the pinion (a gear) rides on a shaft (rack - linear gear) When you turn the steering wheel, the pinion pushes on the rack and makes your wheels turn... Now that pinion must be snug up against that rack to work properly. This is accomplished using a high tension spring and plastic bushing to constantly apply pressure and since it is a spring, it is self adjusting until the spring is maxed out. Then you need to put in shims behind the spring (washers)... That's it...
There are not many parts in a manual rack that can go wrong... When you rebuild one, that is usually what you do...
Now, if you have freeplay in other components, this will not fix it, but will make it better, good luck
fs
Paul Bisioc
Jun 25, 2019 11:29 AM
Mohsin
Oct 7, 2008 01:56 PM
CivicHB93JDM
Sep 8, 2005 09:00 AM
fsp31
18
Apr 29, 2003 05:10 PM
