2000 Accord 2dr EX tech question..Plz Help!
Hello, I just found this site while looking for a troubleshooting problem I am having with my car.
As I was driving last night I ran over a small pothole, and I do mean small, just enough to feel a bump as you would if you we pulling into a driveway. Anyhow, right after I went over the pothole some of my indicator lights came on. The Brake, Battery, the 2 door open and trunk open, and the brake lamp indicator lights all came on at the same time and will not shut off. I have even unpluged the battery itself in hopes of it resetting. The car runs fine and nothing seems to be wrong. Before I take it into Honda and spend buko bucks (warranty just ran out), is there any suggestions that I may try first in hopes of fixing????
Thank you!
Thank you!
i happens to me once, i forgot to wrench down the negative terminal after i took out the battery, when i make a turn and hit a little bump all hell break loose..cel, battery, all light flash and the car's fine
alexyukiya
Apr 28, 2020 05:27 PM
lora king
Mar 27, 2013 12:52 PM
